Drag Racing Tech
To Much Voltage I Need Help
Old Jan 21, 2009 | 12:37 AM
XpEdItIoUs's Avatar
Default To Much Voltage I Need Help
I just finished my car and today was the first time I took it out for a meet. On my way there my cars voltage was at 15-17 volts and my check guages light was on. I have a spal 16" fan, twin 355 fuel pumps, and i use a injector controller. My alternator is stock, Should i replace it with a 200 amp alternator? or do i have a electrical problem somewhere? BTW my battery is in the rear and i have a cut off switch.
Old Jan 21, 2009 | 09:58 AM
SPEEDYws6's Avatar
Did you verify that voltage with a multi meter? Sounds like a bad regulator in the alternator.
