Drag Racing Tech
ABS delete help
Old Jan 25, 2009 | 07:30 PM
93_z28's Avatar
Default ABS delete help
i want to order an ABS delete kit but i dont know if i need a 3 or a 4 channel kit.my car never had a traction control switch,just a low traction light.
the new rear end i have dosnt have the plug in it that ive read means its a 3 channel.so im guessing its out of a 4 channel car.i dont know for sure because i bought it used out of an LS1 car.its a moser 9 inch.
how do i figure out what kit to buy?
Old Jan 25, 2009 | 08:39 PM
ShevrolayZ28's Avatar
If it never had traction control, it is 3 channel.
What year is the car?
Old Jan 25, 2009 | 08:49 PM
93_z28's Avatar
its a 93
Old Jan 25, 2009 | 09:05 PM
Steve Burger's Avatar
LS1TECH Sponsor
We have a kit. I can set you up if you want It is on our site.
Old Jan 25, 2009 | 10:17 PM
93_z28's Avatar
whats the differences between your kit and SJM`s kit?
Old Jan 28, 2009 | 10:33 AM
SJM Manufacturing Inc's Avatar
Your 93 car would be a 3 channel car.
Our kit completely removes your bracket and ABS modulator. It also incorporates a wilwood adjustable proportioning valve to bias your braking system. The base kit is 139.99. The line lock kits-add 40.00, double flare tool-add 20.00.
If you currently own a line lock (ours, Moroso or Hurst style) and tool, then you don't need to repurchase them. Everything you'd need is included in the kit.
Give me a call if you need more assistance.
