Drag Racing Tech
Engine Diaper, where to get one?
Old Jan 26, 2009 | 08:32 PM
Krazy98Z28's Avatar
Default Engine Diaper, where to get one?
The tech director from my track just posted this:
Just a reminder to everyone. As of April 1st 2009 all cars running 9.99 or faster must have a lower engine comtainment system (diaper) or may use a belly pan.Belly pan must be approved by tech department.
Diapers DO NOT have to be SFI 7.1 cert.
Check IHRA rule book for pro classes.
The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and rearward to the rear engine plate or bellhousing and must incorporate a minimum 2 inch highlip on all sides a non flammable,oil absorbent liner inside of retention devise.
Thank You
Buddy Scurto
NED Tech Director.
Where can I get one that fits our cars?
Marco
Old Jan 26, 2009 | 08:37 PM
camscam02's Avatar
at the bottom of this section
https://ls1tech.com/forums/drag-raci...e-diapers.html
Old Jan 26, 2009 | 08:38 PM
jmill96Z's Avatar
removed
Old Jan 26, 2009 | 08:47 PM
Krazy98Z28's Avatar
dam they are pricey
Old Jan 26, 2009 | 10:41 PM
Fast_94_Z's Avatar
i have one from stroud but im running a BBC
Old Jan 27, 2009 | 12:15 AM
pmbmax's Avatar
X2 for stroud it dont cost that much to go first class o SBC
Old Jan 27, 2009 | 06:32 AM
tektrans's Avatar
is this an nhra rule as well?
Old Jan 27, 2009 | 07:31 AM
Fireball's Avatar
its a track rule now unless you are faster than 7.50...some tracks are requring at 9.99
Old Jan 27, 2009 | 07:50 AM
mad_steve's Avatar
We use DRE Engine diapers. They have a couple different selections. Here's their number and website. (217) 454-5289 or (217) 763-6352
Old Jan 27, 2009 | 09:41 AM
Krazy98Z28's Avatar
[QUOTE=mad_steve_08;10931537]We use DRE Engine diapers. They have a couple different selections. Here's their number and website. (217) 454-5289 or (217) 763-6352
Thanks!
That's alot more affordable
Krazy98Z28's Avatar
What size would fit our motors?
Old Jan 27, 2009 | 10:30 AM
JL ws-6's Avatar
Race your car!
Told you the safety stuff was gonna cost ya.
Old Jan 27, 2009 | 10:34 AM
Krazy98Z28's Avatar
$169 isn't gonna break me
Old Jan 27, 2009 | 10:55 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Yup,
To be compliant really sucks!
But it should be budgeted into your total project cost.
Old Jan 27, 2009 | 11:06 AM
datz kool's Avatar
Depends XXX large,it should get by the tech guys at N.E.D.
Sorry Joe ,i had to say it.............
Old Jan 27, 2009 | 12:11 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Our DJ Safety Diapers are 199.95 are NHRA accepted and SFI 7.2 approved.
Diapers are custom fitted and now Available for LS1 with drysumps, F-body pans, and Ls1 Retrofit pans. With easy removal clips removes in seconds, absorbent pads hold up to 10 quarts of oi
Currently have Drysump and wetsump diapers available with and without engine mounts
Why go with a Non SFI diaper now and possible have to buy a new approved diaper next year if they require a sfi sticker/tag
Old Jan 27, 2009 | 12:39 PM
pmbmax's Avatar
The part i dont like after 20 or so passes with a FI car their is going to be some oil leak their just is . what is going to happen if it ever caught fire you have a diaper with oil in it straped to your engine and it is a NHRA rule" Lower engine containment device " any one 7.49 or quicker . I cant find it but if you are Super are Turbo charged and 9.99 or quicker it is required. I remeber reading it i just cant find I have a stroud if fits good but after i put the tabs on i took it off and put it in the trailer. i t will stay their untile i fail tech because of not having it. Just my 2 cents
Old Jan 28, 2009 | 12:17 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
That is Why a properly setup fire suppression system is so important. Safety is the one place you dont want to be cheap on. Orme Brothers has the DJ coldfire systems also. 10lb remote system $566.64..
Old Jan 28, 2009 | 01:21 PM
Fireball's Avatar
Diapers are custom fitted and now Available for LS1 with drysumps, F-body pans, and Ls1 Retrofit pans. With easy removal clips removes in seconds, absorbent pads hold up to 10 quarts of oil
will the wetsump diaper you have for an f-body work with a moroso oil pan?
Old Jan 28, 2009 | 01:33 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Yes it will, the straps are adjustable. to accomodate the added depth.
