Drag Racing Tech
Pinion angle with Spohn arm ???
Old Oct 7, 2003 | 07:24 AM
Reckless's Avatar
Super Moderator
Default Pinion angle with Spohn arm ???
Not sure where to place the angle finder on the rear end. Some say use the thick plate that is part of the torque arm mounting bracket (on bottom of pumpkin). Some say use the webbing that runs horizontally from the rear of the pumpkin toward the pinion. These two are at slightly different angles. So which one should I use?
Old Oct 7, 2003 | 08:16 AM
DERTY's Avatar
The Bull
Default Re: Pinion angle with Spohn arm ???
Use the thick plate that bolts to the bottom of the pumpkin.
Old Oct 7, 2003 | 08:26 AM
Reckless's Avatar
Super Moderator
That is what I have been using since the webbing looks like it actually angles upward slightly. I figures the bracket for the TA would be aligned with the pinion correctly.
Thanks!
Old Oct 7, 2003 | 08:58 AM
Steve Burger's Avatar
LS1TECH Sponsor
I use the thick plate and the drive shaft to get the angle set.
Old Oct 7, 2003 | 10:27 AM
Big Rick's Avatar
I use the pinion and the driveshaft.
Old Oct 7, 2003 | 12:28 PM
Reckless's Avatar
Super Moderator
I also use both the plate and the driveshaft, but wasn't real sure which point on the pinion to use.
Old Oct 7, 2003 | 12:43 PM
Hawkn01's Avatar
[quote]
I use the pinion and the driveshaft. [/quote
The pinion yoke will give you the correct angle.
Old Oct 7, 2003 | 10:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
I pull the driveshaft and use the face of the pinion shaft.
Just remember to zero out the driveshaft angle then go -1 pinion.
I made the mistake of just going -2 from the tranny angle and got a mean vibration.After zeroing out the rotating mass of the driveshaft my rear is at +3 degree's.No more vibration.
Old Oct 8, 2003 | 04:22 PM
MIGHTYMOUSE's Avatar
i have the spoh TA and am runing -3* with no vibration.
Old Oct 8, 2003 | 05:50 PM
DERTY's Avatar
The Bull
I'm at -4.x* with no vibration.
