Drag Racing Tech
Help please on launching.....
Old Feb 3, 2009 | 06:06 AM
trippcobra's Avatar
Default Help please on launching.....
I just got a 2001 ss slp car with a 6spd, its has a couple of bolt ons and 275 street tires, 3.42 rear and stock suspension. whats the best rpm to launch at and what rpm should I shift for the fastest ET? Ive been down the track maybe 1000times, but never in an Ls1 f-body. any help appreciated, It will be about 45 degrees when I run the car at gainesville tomorrow.
Old Feb 3, 2009 | 07:34 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
test and practice !
Old Feb 3, 2009 | 07:41 AM
z28rob18's Avatar
on street tires with a good burnout i launched at 3500 but around 3000 should be good. i shift my lt1 @5600
Old Feb 3, 2009 | 10:07 AM
SuperSlow02's Avatar
On the exact same set up as you I was able to get 1.93 60fts on street tires, best I found to do was slip the clutch from about 4k and ride it through the 60ft. Now obviously this is horrible on the clutch, but up to you if you want to try it.
Old Feb 3, 2009 | 10:58 AM
trippcobra's Avatar
Default best et....
what RPM should I be shifting at??? 6k or 6.2k?? powershifting second or granny, how about third?? all help is much appreciated.
Old Feb 3, 2009 | 11:16 AM
SmurfLSX's Avatar
id say 6k if its stock cam. i granny shift lol powershifting is real hard on **** especially if its not made for it
Old Feb 3, 2009 | 11:28 AM
6k is fine, as to shifting, up to you, I Just powershift mine, seems to net me good results.
Old Feb 3, 2009 | 02:10 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Leave at the RPM the tires will allow, often it will be soft, and your going to be in the 2.2 to at best 2.0 60' range. I've had a great deal of learning to launch a M6 and this year I will be doing some experimintation to see if the car can do 1.5x. I currently pull wheels @ 1.7x
Old Feb 5, 2009 | 01:38 PM
what suspension do you have? Ive been at 1.60s and no day light well at least no one saw it.
Old Feb 5, 2009 | 02:26 PM
BADD SS's Avatar
I hold mine up about 3-4 inches almost to the 60' then it settles down. Im running my own custom suspension in the rear, torque arm, lca's and phr. Up front I have a UMI K member, a arms, and Qa1's.. Bring up the RPM to 6500, and either drop it, or feather it depending on the track. For me, most of the time dropping it works the best. Best 60' of 1.51
Old Feb 5, 2009 | 02:32 PM
Internet Mechanic
A basic recipe.....
Race Weight: ??? Honestly I dont know, w/ me this car is heavy, when the weather clears up I will be re weighing it and the lighter rims will be weighed to figure our the diff.
!Front Swaybar w/ bracket
BMR Adj TQ arm -2 deg Pinion Angle
BMR Rear LCA w/ relocation bracket set to the lowest hole
BMR Adj pan Hard rod
No SFC's (will be adding)
Stock Springs
Stock Shocks
No Air Bag
M6 Trans with Fbody ratio's
Moser 12 bolt w/ 4.10 ring gear
5.5k Dump and pray
on a 26" tall M/T ET Drag (basically the smallest bias ply they make)
4" wide convo pro's in front.
The car was lined up in the groove via a good spotter w/ a decent burnout and 16 psi in the tire.
It hit's so hard the body of the car smashes into the rear and thats why the 60' is in the 1.7's vs the 1.5's where it should be.
I know what needs to be done but I gotta get the $$$ in line.
Old Feb 5, 2009 | 04:15 PM
Same set up in the rear cept mine is UMI, One of my problems has been traction hop which I couldnt really feel through the slicks, but upon watching a video it was obvious. I added LCA/PHB for this season and hope to get some shocks in the back before I return to the track. my goals are also 1.50 60fts, I dont think my LS7 clutch will put up with more past that lol.
Old Feb 5, 2009 | 04:20 PM
BTLD_LS1's Avatar
I finally got mine to pull the front left... A4 with a converter tho, stock suspension with the exception of QA1 drags out front and KYB struts....
Old Feb 5, 2009 | 08:22 PM
stupid autos...
Old Feb 5, 2009 | 09:48 PM
5_02ls1's Avatar
haha ive went 1.60s on bone stock suspension...no ta no sfc,sno nothing.......
to the op theres no magic launch rpm learn your car they are all different....and id powershift at 6 grand....
Old Feb 6, 2009 | 08:23 AM
Internet Mechanic
So a couple of questions...
1) How far is away is your track, and how many times were you going to get that 60'foot
2) How long did that 10 bolt last
3) How many clutches did you fry.
Old Feb 6, 2009 | 05:47 PM
5_02ls1's Avatar
my track is 80 miles 1 way....
the 10 bolt has alot of hardened moser goodies
and my lockup clutch in the 4000 stall fried long ago haha..
stalled a4s pwne m6s....
but i love driving my cobra with the manoal tranny....
id put a t56 in the ta if i didnt think it would slow me down......
Old Feb 8, 2009 | 06:00 PM
Internet Mechanic
Ok, so clarify, is the 1.6 on a m6 or a4 trans??
Sounds like you gave up and moved on, which is fine but is beyond the scope of the poster's topic.
Thanks
Old Feb 9, 2009 | 10:33 PM
5_02ls1's Avatar
damn man it was for laughs lighten up....yeah i have a stalled a4.....and yeah my suspension is all stock....like i told the op in my 1st post no 2 cars launch the same.....practice...
Old Feb 9, 2009 | 11:15 PM
WhiteLTone's Avatar
slip the clutch out if you're on street tires, maybe 3300 rpm.. depending on how the tires hook.. no big burnout either, just a little spin to clean the tires off... then powershift that B#tch like you stole it. Believe it or not - M6 can handle a little beating.. especially if its near stock power levels. Hell i 1.44 60' my buddys cam only m6 goat and slammed every gear w/out takin my foot off the gas at least 20 + times and its still working great.
