Drag Racing Tech
C5: While replacing the clutch, what else should I replace while I'm down there?
Old Feb 14, 2009 | 11:32 PM
user 70810891082's Avatar
Default C5: While replacing the clutch, what else should I replace while I'm down there?
While the entire rear suspension/trans dropped, what should I replace that results in a negligible labor difference? Hardened output shaft, half shaft, trans brace?
Old Feb 14, 2009 | 11:41 PM
socmguy's Avatar
Restricted User
Get a DTE brace. It's worth its weight in gold! A clutch slave is not a bad idea if you're having hydraulic issues either, and DEFINITELY buy a remote clutch bleeder. Half shafts can be installed without the entire rear end dropped.
Old Feb 14, 2009 | 11:43 PM
Thanks... I have most of the clutch items covered, but was more interested in the random parts that would be easier to access.
Old Feb 16, 2009 | 08:24 PM
Anyone else have input?
Old Feb 16, 2009 | 11:21 PM
bgblockelcamino's Avatar
can do the hardened driver output shaft. much easier to do while diff on the bench. if not changing gears go with DTE clutch packs or c6 z06 clutch packs in carrier
