Drag Racing Tech
How to delete ABS?
Old Feb 22, 2009 | 01:33 PM
Black94Z28's Avatar
Default How to delete ABS?
Is there a good write up on this? I just bought a ssbc proporting valve. Has an inlet/outlet on it and a **** on the top, is this the part i need? If so, what now? Love to clean the engine bay up. Thanks
Old Feb 22, 2009 | 02:28 PM
SJM Manufacturing Inc's Avatar
The valve is a good start.
You may not want to hear this but you can consider our ABS delete kits.
The base kit which includes an adjustable wilwood valve and mounting kit is 139.99. It would include ever fitting, preformed lines plus everything else you need to bolt it on the car minus a line lock and minus the double flare tool. If you wanted/needed those two options, the double flare tool is a 20.00 option and our SJM line lock kit (including two switches, wire, LED and misc connects) is a 40.00 option.
All kits include a full writeup with pictures.
Old Feb 22, 2009 | 02:51 PM
01sscam's Avatar
Man-Crush Warning
I have the SJM kit, it was really easy to install and works great.
Old Feb 22, 2009 | 03:50 PM
Deerhunter-Z28's Avatar
How much weight does the ABS save?
Old Feb 22, 2009 | 04:46 PM
Nabdrill's Avatar
+1 for the SJM kit!
Old Feb 22, 2009 | 04:55 PM
Heyfred's Avatar
Weighing on my bathroom ABS unit weighs approx 5lbs..
I just removed the ABS and getting ready to install the SJM ABS delete kit.
Removing the ABS frees up alot of space and makes the area easier to work in if needed.
Old Feb 22, 2009 | 04:59 PM
rusty2198's Avatar
remove the complete brake system that should shave off 50+lbs and cut a big hole on in the floor and FLINTSTONE that thing LOL. J/K I was thinking of removing that big ugly block myself and installing a linelock. Could someone post up some pics of their engine bay with this gone so I can get a idea of how much room it takes up.
Old Feb 22, 2009 | 05:11 PM
I realize it would clean up the engine bay quite a bit, but for only 5lbs I think I'll hold off...lol.
Old Feb 22, 2009 | 05:33 PM
01sscam's Avatar
Man-Crush Warning
Removing the ABS definitely saves more than 5lbs. Contact SJM, they may have the exact weight.
Old Feb 22, 2009 | 05:37 PM
tee-boy's Avatar
ABS saves about 12 pounds.
Old Feb 22, 2009 | 06:02 PM
For the poster's LT1 car, it will be about 16lbs for the bracket and controller.
Total weight removal depends on a few factors. You can remove wiring associated with it...some of them have a separate EBCM which is a pound or so as well. If the car had TCS (since it is a function of the ABS controller) will drop ~19-20lbs from an LS1. If the LS1 doesn't have TCS, ~12-13lbs as mentioned is about right for the bracket and ABS controller w/associated pieces.
If you compare dollar for dollar removing ABS asside from free mods is one of the least expensive best bang for the buck modifications. Most importantly, it free's up headaches associated with ABS issues. It cleans up the engine bay allowing for easier plumbing for forced induction or other modifications to the engine area.
Old Feb 22, 2009 | 06:33 PM
Black94Z28's Avatar
SJM-do you have just a kit of parts minus the proporting valve (since I have) and the line lock, just like fitting and whatever else needed
Old Feb 22, 2009 | 11:16 PM
We could configure it for you as requested.
I think the main problem you're going to have though is placement of your valve. The mounting points are horizontal whereas Wilwood's valve is vertical. This makes positioning challenging (due to surface area in the engine bay you have).
The **** on the wilwood is positioned a bit better making accessibility and control easier in my opinion. Our valves come pre-assembled with appropriate fittings.
I think you're better option is to consider returning the one you recently purchased. It may be less headaches in the end. this is entirely up to you.
Old Feb 23, 2009 | 04:51 AM
IGNANt's Avatar
about to order one from you guys, thanks!
Old Feb 26, 2009 | 12:30 AM
SS4Luck's Avatar
my some like a stupid question, removing the ABS results in what other than weight reduction and what does the valve do?
i know its a noob question please be easy on me
Old Feb 26, 2009 | 05:29 AM
358chevycamaro's Avatar
It allows you to ditch the ABS if you don't want it anymore or if you decide to switch to a rearend to equipped for ABS applications.
The proportioning valve allows you to adjust the front to back bias of the brakes so you are not locking up the rears an the fronts aren't doing hardly a thing, or vice versa.
Old Feb 26, 2009 | 06:04 AM
joelster's Avatar
A lot of guys who do this are running drag racing setups with those little skinny tires up front. When you do this you do not want the majority of your braking force to be done with the front tires, because they will lock up. With the adjustable valve you can configure it however you want it to.
Old Feb 26, 2009 | 08:08 AM
mad_steve's Avatar
Burkhart makes an ABS delete. Call me for pricing. 225-673-3533
Old Feb 26, 2009 | 08:30 AM
Originally, the ABS controller took care of brake bias needs. When you remove ABS, you completely remove all bias controlling. You've got about as much chance as the car being biased correctly as hitting the lottery.
When your brakes are not biased well, brakes are not utilized to maximum efficiency so stopping distances and predicable stops are worsened. Having poor biased braking can be a driving hazard if the rears lock before the fronts (which would be typical). If you're turning and slightly apply the brakes, the rears lock, you're rear-end will swing out like you're doing a doughnut in a parking lot with the emergency brake. An adjustable proportioning valve enables you to adjust for variances.
The valve needs to be adjustable as no one car is going to be the same. Weight distribution, tires, rotors, pads etc effect how your car stops. All of our kits include the adjustable wilwood valve and preformed lines.
Our kits remove the most mass possible as you are removing the entire ABS bracket and controller. It allows for maximum air flow for the engine bay as well as space for other modifications i.e. turbo or supercharger routing. It also makes the car much easier to work on since the area is completely open.
Our kits use preformed hardline only. They enable the user to remove existing braided lines which can increase brake reaction (helps remove spongy brakes from line expansion). Replacing rubber lines (like the stock ones going to your calipers) can be beneficial. Adding braided lines or replacing hard lines with braided lines to your existing hydraulic brake system decreases brake performance.
Old Feb 26, 2009 | 11:19 AM
C_Rules's Avatar
I really really want to do buy this kit to do this mod but the above part has prevented me from doing it. I've asked this before but I have to ask this again on a scale from 1-10 how hard is this to do with the motor on the car. I know the hard part is using the flaring tool down there. Sorry to ask again but I need some convincing that this can be done without a huge effort.
