Drag Racing Tech
Fast 92 1/4 results?
Old Feb 27, 2009 | 11:44 PM
silverz28camaro's Avatar
Default Fast 92 1/4 results?
I see a lot of dyno graphs getting 15-25 depending on mods vs an ls6 manifold, but what really matters it the et and mph to me.
So what are we looking at, Post up your before/after 1/4 fast90 results if there are any here.
Old Feb 28, 2009 | 01:34 PM
no on?.....Any guesses? on a head cam car?
Old Feb 28, 2009 | 02:35 PM
dnkynrbk's Avatar
I didnt see must improvement from going to a ls6 intate and a bbk 80mm to my fast 90 ported but my motor was mostly stock. My new motor I have heads and a huge cam. I think it depends on your set up. I would not waist my money on the 92mm if I did not have the cam and heads to benefit from the extra air. just my 2 cents.
Old Feb 28, 2009 | 03:04 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
Best before refreshed tranny, TCI SSF 3800 stall and ported Fast 92: 11.78 @ 114.55. Best after refreshed tranny, Pro Edge 4000 stall and ported Fast 92: 11.57 @ 117.46. Different dates, but similar temps and humidity.
Even though I had a few extra changes, I believe the Fast 92 had the biggest impact on my mph.
Old Feb 28, 2009 | 04:23 PM
dnkynrbk's Avatar
what was your 60ft on both runs. that makes a big impact. did you go from a ls1 to the fast 90
Old Feb 28, 2009 | 04:35 PM
Yeah i don't see the converter giving you more mph, but what was both 60's. If i can get 1-2 tenths and 2-3 mph i'll buy one.
Old Feb 28, 2009 | 04:40 PM
shortdog's Avatar
My 60' for the 11.78 pass was 1.60 and the 60' for the 11.57 pass was 1.61. Though, the converter I have in my ride is larger, it's tighter for the bottle. The TCI was super loose.
I went from a LS6 intake to a ported Fast 92.
On a different note, I hope to gain a mph or so with the Fasttoys 90mm lid and SSRA this Spring. Brad (silverz28), I'll let you know if it helped just in case you decide to go this route, along with the Fast 92.
Old Feb 28, 2009 | 05:55 PM
90mm lid? where is this at? I bought the 85mm lid and maf. I though it was a nice peice, but i don't have any before/after with it, plus my tb is still 78mm
Old Feb 28, 2009 | 06:08 PM
shortdog's Avatar
Typo, my bad. In reality though, the opening of the lid is actually larger than 85mm. It's more like 90-95mm.
I'll find out in three weeks if it helped.
Old Feb 28, 2009 | 06:33 PM
Well then it should be the same one i have, I think it helped, looks badass to. I did have slight hood clearance issue, but grinding the bottom of the plastic tray solved issue
