Drag Racing Tech
Installing vic jr intake. MAP Sensor???
Old Feb 28, 2009 | 08:39 PM
BlackWS666's Avatar
Default Installing vic jr intake. MAP Sensor???
For anyone with a vic jr intake on their LS1 how did you go about hooking up the MAP sensor? Thanks.
Old Feb 28, 2009 | 08:54 PM
Reboot's Avatar
search NosboySS. He had one in the classifed section about a month ago with pictures
Old Feb 28, 2009 | 08:56 PM
Reboot's Avatar
here you go http://i132.photobucket.com/albums/q2/BOTLFED12/007.jpg
Old Feb 28, 2009 | 09:55 PM
FASTFATBOY's Avatar
Make you a little "L" bracket that bolts to one of the intake/carb flange bolts and mount it to that in the back.
Old Feb 28, 2009 | 10:25 PM
Nabdrill's Avatar
I used the stock one. Mounted it on the firewall above the back of the engine. I took off the orange rubber and used 3/8 hose. I didn't have to make a bracket, I've cut my cowling back so I just cut a notch in the cowling left at the firewall that the MAP would slide on. I'll have pics on my build thread tomm.
Old Mar 1, 2009 | 01:50 AM
BlackWS666's Avatar
Hey guy, AWESOME. Exactly what I was needed to see. I just havent seen anyone do a write-up on installing one, and how to modify the sensor locations.
Old Mar 1, 2009 | 04:44 AM
BlackWS666's Avatar
Anyone know the size of these fittings? And correct size hose? My car is about 30 miles away, and I only work on it on the weekends. Dont want to make the drive for a measurement if someone else has the knowledge available. Thanks
Attached Thumbnails Installing vic jr intake.  MAP Sensor???-vic-jr-sensor-setup-2.jpg
Old Mar 1, 2009 | 05:28 AM
98CamZ28's Avatar
Well, i'm not sure what you're setup is now but here is how I did it on my old setup, just ran it directly in the elbow
And on the new setup I needed to run a spacer to clear my fogger and just drilled a hole into the spacer and mounted it in there (you can see the blue labed on the sensor just below the tps sensor)
Old Mar 1, 2009 | 11:08 PM
Nabdrill's Avatar
Old Mar 2, 2009 | 01:24 AM
BlackWS666's Avatar
Originally Posted by Nabdrill
What size fitting is that, and hose? Thanks for the picture man
Old Mar 2, 2009 | 07:53 AM
TS6's Avatar
TS6
The larger one is probably 1/2" (maybe 3/8") and the smaller is 1/8". Both are NPT.
Old Mar 2, 2009 | 08:53 AM
Nabdrill's Avatar
the fitting is 3/8" NPT thread by 1/4" barb (brass) and the hose is standard 1/4" hose. you'll have to remove the orange rubber that's on the stock MAP port and the hose will fit snuggly.
patrick
Old Mar 2, 2009 | 11:00 AM
BlackWS666's Avatar
Thanks a bunch man. I will get some pictures of the setup as soon as its back in.
Old Mar 2, 2009 | 12:53 PM
Nabdrill's Avatar
What's your front susp set-up to get the front tires tucked in like that?
Old Mar 2, 2009 | 03:49 PM
Nabdrill's Avatar
Forgot to mention earlier... If you're running a throttle bottle or carb make you sure you check the spacing before you get your fittings. Depending on what you've got, you may have to get some low profile fittings.
Old Mar 2, 2009 | 03:56 PM
TS6's Avatar
TS6
Its just sitting, its not really set like that. He's gotta raise it back up to drive it. Not that it'll ever run anyway.
Old Mar 2, 2009 | 04:14 PM
BlackWS666's Avatar
This motha fuka right her^^^^. haah. That hurts coming from a guy who wants to sell his f-body for a ***** *** corvette. Yea he is right though, I probably wont be able to drive it the way it sits, the torque arm loop is about 4 inchs off the ground. So it will be coming back up another good 1.5 inchs. I will keep that in mind, but im sure it will be ok. Im running the edelbrock elbow with a holley 90mm TB. tons of room .
Attached Thumbnails Installing vic jr intake.  MAP Sensor???-lalannecorvette.jpg
Old Mar 2, 2009 | 10:21 PM
TS6's Avatar
TS6
Nice picture. I hope you get crabs.
Missed your call tonight, I was busy losing money at the poker table. They frown on cell phone use during the game.
Old Mar 3, 2009 | 11:03 PM
BlackWS666's Avatar
Here is the setup so far. got my MAP sensor today, and all fittings. Hopefully will start this coming week, or so.
