Drag Racing Tech
Need help with fuel system 02 camaro
Old Mar 1, 2009 | 10:01 AM
HotRod H269's Avatar
Default Need help with fuel system 02 camaro
I recently bought a 02 camaro wrecked in the front end,no motor transmission.I got the frontend fixed and a new bmr k-member for a small
block chevy.I'm in the process of of fixing the fuel system.
I removed the rearend,gastank,and fuel lines yesterday.I want to run the gas lines on the passanger side.Is there any way to keep the factory pump and just put a regulator up front.This car will be carburated.What should I do with the return line an vent.I want to keep my factory fuel gauge in the dash working if possible.I plan on bracket racing the car and going to some cruz in's.Thanks in advance.
