Drag Racing Tech
abs delete wiring questions
Old Mar 24, 2009 | 10:27 AM
transamsam98's Avatar
Default abs delete wiring questions
the sensors behind the wheels front and rear(4 channel car swapped to 9 inch non abs equiped) what wires can be removed? do the front sensors serve any purpose once the rears are deleted? I will be doing the abs block delete/ line lock once I have the cash as well if this makes any difference.
Old Mar 24, 2009 | 04:59 PM
Magic Man's Avatar
Abs is faulted out so they don't do anything and once you do abs delete block everything is out of the picture.
Old Mar 24, 2009 | 10:11 PM
ok I m aware of the abs being non op and am aware of the abs delete kits wich replace the block and use the praportioning valve my major question is reguarding the wires/ sensors and where they are and what can be removed.
Old Mar 25, 2009 | 08:10 AM
fitz98ta's Avatar
you can remove all the sensors once the abs block is removed. Only wires I cut were the plugs that plug into the sensors at the front wheels. You can also remove the sensor wires at the rear sensors as well if you so desire. Depending on how serious about it you are, you could pull your loom off your body harness and cut the wires that go to the abs module as far back as you can. I didn't do that part, I just moved the plug under the car.
