Drag Racing Tech
Best hooking 17?
Old Apr 2, 2009 | 09:27 PM
Getav8's Avatar
Default Best hooking 17?
I have 17x11 bogarts on the back of a m6 car, what would be the best hooking tire and in what size.
I know a lot of people talk about the m/t but what would be the best size if this is the best tire. 295 or 315.
Old Apr 2, 2009 | 09:46 PM
firefighting1101's Avatar
m&h has a set of 315's that are 28" tall that are pretty badass
Old Apr 2, 2009 | 10:05 PM
itsjustaSB's Avatar
yes i have those tires but they are a very narrow 315 like 10.3 inches tread width might look alittle goofy on a 11 inch rim i have them on a 9.5 rim and they look perfect on them i run them for the height but i will say they hook like a sum bitch
unless u need the height getav8 i would run a mt 315 on there they are a badass tire
Old Apr 2, 2009 | 11:09 PM
cdubbzz's Avatar
MT's 295/45 would give you more sidewall (27.4") to help absorb the initial shock when launching while
the 315's give a wider contact patch but lower profile (25.6").
I've used MT 275/40's, 295/45's, Nitto 315's, and M&H 325/45's
Overall I like the MT 295/45's best...little more sidewall but height doesn't kill your gear like the M&H's(28")
Old Apr 2, 2009 | 11:32 PM
m&h has 325's too
Old Apr 3, 2009 | 12:14 AM
Getav8's Avatar
I am running a 315 bfg drag radial but the best I have been able to muster out of them is a 1.7 and that was only once. It is usually a 1.8.
Some people are telling me the 295 is better than the 315. But I haven't actually talk to anyone who has personally run both on a m6 car.
Old Apr 3, 2009 | 10:54 AM
Getav8's Avatar
I am trying to get into the 1.5 range. Is this likely with a m6 on a 17 or is it pretty much a pipe dream?
Old Apr 3, 2009 | 11:04 AM
dlove's Avatar
I went 10.3 @ 132 on a 17'' M&H 275.
Old Apr 3, 2009 | 11:25 AM
Getav8's Avatar
M6 or autiomatic is the big question. I am a m6
Old Apr 3, 2009 | 12:05 PM
dlove's Avatar
auto.
Old Apr 3, 2009 | 12:45 PM
T6Rocket's Avatar
Originally Posted by firefighting1101
m&h has 325's too
Yeah, 325/45/17, 28" tall, 10.3" tread width, will work with an 11" rim.
http://www.mandhtires.com/store.php?...on=show_detail
They also make a 390/40-17 if you can fit it in the wheelwell!
Al
Old Apr 3, 2009 | 01:39 PM
veee8's Avatar
I have been 9.5 at 150 on M&H 325-40-18 drag radials, with a soft 1.51 sixty ft. Hoping to knock that down to the 1.3 range and be in the 8's on this Sunday. I don't know what the record is on 18" M&H's is, but I am gunning for it.
Old Apr 3, 2009 | 03:21 PM
Getav8's Avatar
Al
That looks like a lot of tire, I wonder if I can fit the 325 in there.
Old Apr 4, 2009 | 03:54 PM
slick1851's Avatar
Whatever this guy is running!
http://videos.streetfire.net/video/8...-17_198475.htm
Old Apr 4, 2009 | 05:01 PM
daniel6718's Avatar
Originally Posted by slick1851
i hate that video that mustangs basically a racecar...mightymouse car is a million times more streetable and better example
Old Apr 5, 2009 | 10:03 AM
cablebandit's Avatar
on my 1 pass so far i did a 1.48 60' on my MT 315/35/17drs
Old Apr 5, 2009 | 10:59 AM
Randy WS6's Avatar
Hoosier make a hell of a DR. also
Old Apr 5, 2009 | 09:11 PM
Getav8's Avatar
I see you got a yamk so you are an auto, I am in a M6
Old Apr 6, 2009 | 06:29 PM
i did leave off the tbrake at 2psi so that is closer to a m6
Old Apr 7, 2009 | 06:56 PM
koolrayz's Avatar
Al
Oh they fit
