N/a in the eights?
440ci
.800 lift solid roller
400+cfm heads
8500 rpm
At this point its all in the set up and alot of seat time.
https://ls1tech.com/forums/drag-raci...s-any-c-i.html
Also, plan on lots of maintenance. Lots of wear and tear on the valvetrain, potential short lifespan on the rods and crank.
Where you'd just be working out a run of the mill big block to get these types of numbers, you'd be beating the **** out of the LSX to get into the 8's.
8.90's @ 152 NA
393"
Yates canted valve heads, flowed almost 400CFM @ .800
Small Solid Roller 27x/28x @ .050 with .8xx/.8xx lift
Cast Intake Single carb, Dominator
14:1
Motor made right at 800 FWHP
Shift @ 9000 RPM
Motor has all the goodies.....titanium valves, retainers, Belt Drive, etc...
Pic of engine:
good heads-perfermance inductions c5r heads would be best
intake-perforamance induction single plane or sheetmetal
valve train-jesel rockers,.937 keyway lifters,7/16 pushrods etc.
big bore-to allow the heads to flow properly
lots of compression-13+
light rotating asy for high rpm use-alum rods,lightweight crank
rigid block-everything needs to stay were it belongs at high rpms
good oiling system-dry sump,proper windage tray etc.
expect to pay $25,000+ for an engine like this
Sounds about right. But if ya want to go fast, that's what it takes. Doesn't matter what the car/setup is, 8 second setups are 25 grand. Sure you can spend less on the motor and go FI, but at the end of the day it's still all gonna add up.
Scary but this figures about right, 25 grand for a 8.90 setup, and every tenth faster you want to go, add about 1100 bucks. Sounds silly but do the math it works out
