Drag Racing Tech
clutch/flywheel combos
Old Apr 3, 2009 | 10:42 AM
lt1camaro95's Avatar
Default clutch/flywheel combos
What clutchs and flywheels are you using for cars with more nuts. I am running a 408 and probably capable of high tens but my POS LS7 clutch and flywheel keeps sucking ***. So what are you guys using?
Old Apr 10, 2009 | 07:38 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
I moved this here, it should get more action in this section.
Coach
Old Apr 10, 2009 | 08:20 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Under 500hp, but even if you spayed it, it would be fine!
Textrailia oz700 Z-grip w/ their flywheel
Tick Performance Master Cyl.
Little over 1k by the time your done but will handle the power, take off the limiter launches, and powershifts with ease since Tick uses a Tilton M/C to increase fluid to push.
Old Apr 10, 2009 | 08:25 AM
z28rob18's Avatar
with the lt1 i dont have as many options but im goin mcleod twin with the steel flywheel.
