Drag Racing Tech
belt issues!!
Old Apr 3, 2009 | 01:58 PM
SoundsZ28's Avatar
Default belt issues!!
i got my car back together but i was wondering can i not use the powersteering pump? i mean i need to know if i can run a belt without using the powersteering pump? all my brackets are the stock ones... so i need to know how to run the water pump, alt, and tensioner without using power steeering
Old Apr 5, 2009 | 04:35 PM
n20fedws6's Avatar
You can use a belt off of a 93 or 91 (cant remember what year it is, but it might be the same belt) Ford escort with A/C. It will run everything but the Power stearing. The bottom bolt that holds the altenator on will have to be clearanced a little, you will see it once get the belt on right. Here is a diagram that I have spent the last couple of days working on. lol
File Type: bmp
Old Apr 5, 2009 | 05:10 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'm running a 51.5" belt
Only have Upper Tensioner, Water Pump, Alternator, Crank
