Drag Racing Tech
Which Torque Arm for my setup???
Old Apr 9, 2009 | 06:36 PM
V6 Bird's Avatar
Originally Posted by built408
Well I think I'm just going to try out the bmr trans mounted torque arm with their relocation crossmember for a th400. If it doesn't perform the way I want it, then I will try out the madman or wolfe arm. Thanks all!!
Random Tech is a much better unit.
Old Apr 9, 2009 | 08:30 PM
N2RACINGLS1's's Avatar
Originally Posted by JL ws-6
Spohn arm isn't bad, but the ground clearnce is pretty bad when you lower the car, to the point that loading/unloading out of a trailer could be a problem if the car sits low, and it may not work with the exhaust setup.
Spohn is what I have on my car in mild steel with poly bushings and it is a great torque arm! I installed the one that works with long tube headers and a performance y-pipe it works with no problem.
Now my car is not lowered in the back except for the spring mod where I added the heater hose and removed the rubber pad. Since I run 26 inch slicks I would think it is just as low to the ground as built408's will be since he is going to use 28 inch slicks. I have never really had a problem with hitting anything with the torque arm.
The torque has produced many low 1.40's NA and some high 1.30's NA. My best 60 ft to date is 1.34 and that was on a 75 shot of nitrous on a 26 inch slick within two inches of dragging the back bumper so I was told. My car is a 346 H/C/I car with TH400 and 4.10 gear really nothing special but I am proud of what it has done. The car has ran a best of 10.53 NA and 10.25 on a 75 HP nitrous shot and weighs 3,350 lbs. +/-.
I hope this helps!
N2
Old Apr 9, 2009 | 08:41 PM
built408's Avatar
The car is lowered a good amount, and sat VERY low with the firehawk wheels. I haven't even lowered it off the lift yet with the draglites and 28 inch slicks, so I'm sure it raised it up some.
Old Apr 10, 2009 | 07:11 PM
JL ws-6's Avatar
Race your car!
Spohn arm I had sat lot, but I had to shim the xmember down a little to clear the 4 inch collector on my old qtp y pipe setup.
The spohn unit isn't a bad piece, but a budd of mine has my old one on his car and the xmember hits on the trailer when he unloads the car if he doesn't use the boards.... so it's kind of a pita. His car is low, about 2 inches lower then stock in the front and the back has the spring isolaters out.
Old Apr 10, 2009 | 08:05 PM
Well I have never driven my car onto an open trailer with ramps. The open trailer I had was a Sloan Quick Load and it was a roll back trailer and was great.
As already stated there are many good torque arms out there I am sure you will find the one that works for you! From what JL is saying I guess if you are using an open trailer with ramps that are short with and a break point on the trailer with min dove tail you may have a problem with many torque arms. If you are using a enclosed trailer with standard ramp door you should be OK with most of the aftermarket torque arms.
Good Luck on your build looks like the car is going to fly!
N2
Old Apr 10, 2009 | 08:23 PM
JL ws-6's Avatar
Race your car!
He's got an enclosed trailer, not sure what brand but without a set of boards it will bottom the crossmember out on the lip of the door when the car is in the middle of unloading.
He's got his car sitting low, with a 26 inch tire on it though, so it's really low especially when the tires are down at 13 to 15 psi where he runs them.
But, with stock tires on it does the same thing so I dunno.
Old Apr 10, 2009 | 08:47 PM
JL - I have a suggestion for him.
Remove the 18 inch flip down extension and install a 36 inch extension, then remove the rubber pads on the door and install the taller pad they use for dragster trailer doors. It holds the main door higher off the ground taking more of the angle out of the ramp with the 36 inch flip down ramp it levels the entry point of the ramp. It makes a big difference!
He can even install the smaller rubber pads at the end of the 36 inch extension ramp where it meets the ground and install two 2x4 angled sections on the 36 inch flip down ramp under the wheel path of the car where it drives onto the ramp. This works great and should solve his problem.
N2
Old Apr 11, 2009 | 03:33 AM
kmracer's Avatar
comments on mid west's setup?
Old Apr 11, 2009 | 06:07 AM
JL ws-6's Avatar
Race your car!
N2
Yeah we talked about doing that stuff... I dunno what he's up to with it right now though. He moved out midwest with his g/f and I think the car and trailer are still here in CT.... not sure when that stuff is heading out there.
Back on topic....
The midwest setup looks decent as well. I'm not a huge fan ot the little side plates (I apologize if I'm thinking of someone else's setup but without a direct link to which one I'm not 100% sure) although noone's ever had any problems with them. they just look like something that could break/crack to me.
Old Apr 12, 2009 | 12:16 AM
kmracer's Avatar
http://www.midwestchassis.com/products.html
theres the only pics of the mid west i can find without digging. i'll post more when my buddies setup gets here...
which was supposed to be here the FIRST btw.
By Brett Foote | 2026-06-04 05:00:17
