Checking Coil Packs
We had a problem with my car breaking up when I would stage the car on the convert. I changed the coil packs from my Dads car and it cleared up the problem. I really dont want to replace all of them if I dont have to.
Coach
take a know good coil and see what reading you get for your baseline. but! this is not a perfect test! i do this with injectors and have had the readings good and still have a bad injector!
if you have a digital oscillascope? this would be the best way to test them. hook it up and you can watch your coil output under running and load conditions. then if there is a break up of the coil, it will show on the screen.
High voltage will arc where you wouldnt' expect it, if the seals in the coil packs ever went bad, that's all it takes for a little moisture/contamination to get in there and then it will start arcing. Higher loads (rpm in this case) will make it worse as well.
I hate to say it but they're gonna be a pita to see which is arcing. Only real way would be to have a scanner hooked up and see which cyl. is misfiring... and start with that. But, I assume you have your knock sensors out and don't have that option.
Maybe time to upgrade to some 6 litre truck coils, and leave your 8 as spares for maybe one of the other cars in the stable that may still have the knock sensors in it.
Actually, swapping them one at a time with one of those cars and watching on that car for a misfire might be the best way to find the bad one... or 2 or however many may be going.
good hunting
http://www.bmotorsports.com/shop/pro...oducts_id/1591
You also want to check the connections by wiggling them while running to see if you have an intermittent connection in the harness somewhere. Sometimes it can be a bad factory crimp or the terminals can be damaged or the spring elements worn out. We carry the connectors for both the coils themselves and for the coil subharness.
A scope measuring across a current sense resistor would tell you about each coils performance but this sort of check is typically overkill when you can simply replace the parts for less in time/money.
