Drag Racing Tech
Lowering front end with Hals, good or bad?
Old Oct 27, 2003 | 02:46 AM
quickWS6's Avatar
Default Lowering front end with Hals, good or bad?
Usually lowering the car hurts weight transfer, but does this apply with Hal shocks and springs? I want to lower the front end a little, but will it hurt weight transfer since I can still loosen the shocks? I don't think it would since the springs aren't stiff at all either.
Old Oct 27, 2003 | 03:56 PM
Stu's Avatar
Stu
It actually helped my weight to transfer. The only down side is if you dont have a long shutdown area at your track. When you get on the brakes the nose dips pretty severely. Hit the brakes hard enuff and your oil pan could be damaged. I set mine on 4 and pull 1.58 60's purty consistently.
Stu
