Drag Racing Tech
whats a good 60ft for me?
Old Apr 17, 2009 | 09:14 PM
firechicken76's Avatar
Default whats a good 60ft for me?
1988 Trans am GTA 02 ls1/t56
underdrive pulley | long tubes | ORY | ls6 intake | Ford 9" W/ lockr 4.11s |Ported TB| SLP Loud mouth | K&N intake | Hurst shifter | 1" drop eibach springs| kyb shocks| Wilwood 4 piston disc brakes/ rotors | subframe connects | tubular lower control arms | edelbrock torque arm and panhard bar | bmt shock tower brace | hellwig sway bar | Stock 16" wheels with Toyo RA1 tires
i ran it the other day and it was a 2.2 60ft with a 13.2 quarter, i had 255 toyo ra1's, if i had some real drag radials what kind of 60ft could i see? 1.60?
Old Apr 17, 2009 | 09:59 PM
jetlag's Avatar
Old Apr 17, 2009 | 10:36 PM
Originally Posted by jetlag
1.61..
so i could see a 6/10 increase in quarter mile?
Old Apr 17, 2009 | 11:02 PM
jetlag's Avatar
More than that...I think if you can hook and drive good, a low 12 high 11 should be there. A friend of mine has pretty much the same mods, and he went 11.80s.
Old Apr 17, 2009 | 11:48 PM
Hector's Avatar
Forget about drag radials, you need bias-ply ET Streets. Shoot for 1.8 before you start thinking about 1.6 And if you have a stock clutch it won't last long. Good luck.
Old Apr 18, 2009 | 12:20 AM
itsjustaSB's Avatar
what was the mph on that run
Old Apr 18, 2009 | 01:13 AM
well, i used a gtech, and i let off before the run was over, so it was like 92mph, i dont have a track very close, its about 100 miles, i want to get up there, or find a nice road to use my gtech on.
since we are talking about clutches, i am just getting ready to do a build on my motor.
cam mti x1 230 227 | .591 .571 | 112
ported 799 casting ls2 heads
lifter
springs
p. rods
etc.
so ill definitly need a new clutch, i was just going to go with an ls7, that a good idea?
Old Apr 19, 2009 | 10:20 AM
itsjustaSB's Avatar
your g tech sems to be alittle off that 60 and mph is like a high 14 sec car soo i would get to track so u can get some accurate readings
by your sig i would think your like a mid to high 12 car at about 108mph with 2.0 60 on street tires
on some drags u could probly see some low 12s with around a 1.6 60 if u can launch your 6 speed
Old Apr 19, 2009 | 11:57 AM
ran out of road, so i had to hit the brakes, if i would of stayed in it, i would of had probably over 110. i hit the brakes at 12.1 seconds according to the gtech playback.
Old Apr 19, 2009 | 01:52 PM
how about a clutch for my build? ls7? i plan to do some racing with it.
Old Apr 19, 2009 | 02:05 PM
98blueSScamaro's Avatar
lose the lowering springs and go to stock cut springs and good shocks just make sure you only cut a little at a time. and oz700zgrip
Old Apr 19, 2009 | 02:16 PM
im not looking for a straight line car only, im using kyb shocks and struts, those bad?
Old Apr 19, 2009 | 02:31 PM
oz700zgrip is nice, but i dont have 1000 to spend on a clutch....is the ls7 any good for drag racing?
Old Apr 19, 2009 | 02:54 PM
jetlag's Avatar
Pffttt, fancy shocks and springs are overrated. I'm pulling 1.45s with Eibach Sportlines and stock shocks.
Old Apr 22, 2009 | 02:28 AM
any other suggestions on a clutch?
Old Apr 22, 2009 | 11:13 AM
jetlag's Avatar
A friend of mine is using a Monster clutch with Tick master cylinder and it is working really good.
Old Apr 22, 2009 | 11:37 AM
BigKap94z's Avatar
I have had very good luck with Spec clutches. Anything in the 1.6's with a mildly modified F body with a stick would be considered very good to me.
Old Apr 22, 2009 | 02:47 PM
CamaroRacing12's Avatar
i bet u will pull a 1.81 best first night out with DR's
Old Apr 22, 2009 | 03:08 PM
c0ncEpT's Avatar
I agree.
You really need to go to a bias ply ET street or similar with that 6 speed.
Old Apr 22, 2009 | 08:38 PM
is that good? sorry, ive never been to the strip b4...
