Rear sway bar
check with the stock guys todd. whats the site? class racers forum.com or something? maybe check with S&W they make stuff for shockers.
Oh, look at that TRZ real anti-roll bar. that bolts to the panhard rod brace, and offsets the panhard rod behind the stock placement. But bolts to all and only the stock holes. That might work for you. I don't know if any stockers are running that???
I think you have to weld the endlink tabs to the housing tubes. But you can probably make a bracket to bolt them to the old brackets that hold the stock bars bushing?? what housing you running? Most use the strange 12bolts right?
I run the BMR sway bar. The rules say that you can beef-up stock suspension mounting points. It is add-on traction aids that can't be welded. At least that's the way that I see it. The BMR is a stock replacement, so I really don't see an issue. It is a great piece that really works well. I can run really low 1.3 sixty foot times. I do not preload the sway bar. I use an air bag in the passenger rear spring for fine tuning.
Good Luck,
Daren
Good Luck,
Daren
fwiw the kit is lighter than all of the stock stuff you pull off compared to some of the solid drag bars adding quite a bit.
possible problem for you is the swaybar does not mount to the car anywhere near the factory location, but is definitely only bolted on in factory bolt holes.
http://fastrides.com/photos/mm/image.../original.aspx
i thought my new setup was going to need an anti roll bar, but im still sporting my suspenion techniques 1" sway bar mounted up with poly stock style end links.
its been on my car for years and always left strait. im about the only guy i know that leaves strait with a sway bar.
1.37-1.38 60ft at 3300#
will you break the rules with the stud mount being weld in, or can you drill holes and bolt it in the factory spot?
With our ARB setup, to load the chassis you need to SHORTEN THE PASSENGER SIDE link. Most ARB setups have the bar mounted to the chassis above the rear with the links going downward, so lengthening the passenger side loads the chassis.
