Drag Racing Tech
Why can't I hook?
Old Jun 11, 2009 | 09:06 AM
MikeG's Avatar
Originally Posted by BlackScreaminMachine
Like said, get some line lock.
I will. But I don't think thats the problem at this point.
Originally Posted by chrs1313
you will like the MT drag radials...pulled 1.38 here with them cam only...
i would be happy with a low 1.5x 60ft SI and PT4000, so you are not too far off
That's exactly what I'm looking for. I just want something under a 1.55.
Originally Posted by omcar
How about installing a set of rear QA1s single adjustable shocks set at 4-5.
I'm getting a good deal on some hoosier DR's, if those don't work (doubt it) then I'll look into more susp. mods.
Old Jun 12, 2009 | 07:47 PM
blownbird355's Avatar
Originally Posted by Captain InsaneO
With ET streets I have had good luck with 12-13 PSI and my burnout is short. I stay in the water box till they smoke, then roll out of it. I have stock front suspension and still cut 1.56 60'
So you sling wtr on your car then let it drip all the way to the line and maybe more?
Old Jun 12, 2009 | 10:12 PM
MrElectric03's Avatar
Are you burning out in 1st or 2nd?
Old Jun 13, 2009 | 12:44 AM
Captain InsaneO's Avatar
I assume you don' know what I'm talking about. Maybe I didn't describe it well enough. My burnout is basically like most others you see. You get the tires wet, roll out of the box some, do your burnout, and roll out of it short of prestage. It's a pretty common way for doing a burnout.
Old Jun 13, 2009 | 11:00 AM
MikeG's Avatar
First then second.
