26 or 28 inch tire?!?!
Providing you can hook up I would use the 26 inch for the 1/8th
I have no problem hooking up with my 3 year old 26 inch et drags and 410 gears and leaving on the transbrake at 5200 rpm but I also dont have the rwhp you have(I only have 451 rwhp)
your suspenton tune will also play a large part and also if you spray out of the hole or not
The car better be really heavy though if it's only trapping that mph with that power though. I'm @ 3350 and can pop off 142+ like clockwork and I know it's not making much more then 600 at the tires.
4.10's and a 28 should be good for 145+ without seeing more then 7000 rpm, if you're on the limiter as it is now, either your limiter is way too low, or your tranny/converter is slipping like mad.
Tire requirements change when raceweight and power levels change, this also applies to suspension and tire compounds.
