Tubes in E/T streets
You might get more help there.
Coach
If you have a hard launcher...I'd screw the tires to the rim to. If you spin the tire/tube, you can have a disaster on your hands
.. so I need to pull the current valve stems out so I can drill 'em open befire putting tubes in. Thanks. Do you remember what size drill bit? I'm assuming you used the m/t tubes. Any good tire shop can mount your tires with tubes.
I was talking about the Florida section because you asked about the Orlando area.
Good luck.
