wt yall think
i will stay with a stock converter no mater what!
i was thinkin about the ASA cam but maybe that would be a little too high in the rpm range for a stock converter.
so what do yall think TR224 or what are some suggestions?
You probably already know this so I am as curious as I can be as to why.
You staying with the stock gears too? Maybe install a direct port nitrous system with the stock spark plugs??? J/K!
Oh, and to answer your question. I think the stock cam is way too much for the stock converter.
well ill tell u my secret
I only want to run low 12.12.10,12.20,etc I only bracket race but in street class which is no faster than 12.00 so if i can make the most MPH out of the bunch i have the advantage
And if i accomplish this with just a cam and stock converter it will prolly leave the line like a dog therefore less breakdown,no changing tires every fri and sat no problems hooking!!understand
