New 8.50 cage getting done.
Yea right. Like we believe that. You'll run a 9.29, make a change or 2 and run a 9.09 ect ect.
I said 12's was it, then 10's, then 8's, ect. You can't trust anything we say, we always want more.
It sure did come out sweet, that's for damn sure!!
I'd need a new short block (shelf pistons wont take the abuse) and bigger blower to get in the 8s solid - or theft recovery it. For now I'll have to be satisfied with getting what I can out of the parts involved. Doing a cage wont make it any faster unfortunately, the BS3 will help a bit but I did that mainly for consistency.
did/do you plot out the suspension on the 4th gen cars?
what angles do you have your lca's and ta...
how far from your axel is your IC and how high off the ground?
just curious
TA angle doesnt matter much if its sliding on the front, the angle is whatever it is to clear my exhaust and driveshaft loop and put the driveline angle where I want it.
LCA angle is a couple degrees up (higher in the front), that puts the IC at about the middle of the engine at the camshaft CL, thats actualy hitting the tires a little harder then I like but its OK with the power I'm making now, when I add more power it will be a wheelstander so I'll lower the car a little to take some LCA angle out.
you actually have put together a few cars that work identical and you dont make money building these cars so i feel your input is very realistic and not Inet BS... lol
but these TA cars really have me confused especially with the shackle thats on them...
alot of the people i talk to say to treat them like a ladder bar car but im not so sure that's the right direction to take.
it sounds like my car is pretty spot-on by the way you described your lca angle and TA but i want to be able to plot it out and see for sure.
sorry for hi-jacking
you didnt say anything, lol
To oversimplify it, if nothing is binding the only thing that you need to be concerned about is the length of the TA (more power = longer is better) and the angle of the LCAs. .
