Drag Racing Tech
thinking about going glide
Old Aug 8, 2009 | 01:57 AM
daniel6718's Avatar
Default thinking about going glide
what all do i need in it? i know a local guy said he had one sraight from the junkyard no brake no shift kit nothing and his car went 5.20's in the 1/8
my cars a 346 car with 225 shot and 9 inch...i want a trans brake, anything else i should look for? i hear you almsot always get a turbo input shaft so you can run a 350/400 converter...also what kinda price range do these run?
then i gota dump a ton of cash on the converter
also what is needed besides a driveshaft and a crossmember? tranny bolts to the motor, any spacer for the flywheel/converter?
Old Aug 8, 2009 | 10:31 AM
mrdragster1970's Avatar
6 & 8 Second Club
I would highly doubt and need to see a stock used glide run a 5.20. That's ~1000 HP
When you order a glide, you do want a turbo shaft, there are 1000's of converters out there
you can buy or borrow in an emergency.
Like anything, the price can be from a few hundred to several thousand.
Good luck.
Old Aug 8, 2009 | 07:10 PM
tektrans's Avatar
I don't think you need a glide at your power level.
Old Aug 8, 2009 | 08:04 PM
Gen414's Avatar
If you are stick going auto, I would go 350/400 instead of a glide. Your car is heavy, and a 3 speed would help out with your power.
So, unless you come across a smoking deal, I would pass on teh glide.
Now that I put in my .02, and that was NOT what you asked, so...
yes, you need an adapter. Crank setup is different from Gen I from which the PG was designed for and Gen III/IV as you know. GM has one (get ahold of Scroggin).
