Drag Racing Tech
M6 60ft help
Old Aug 15, 2009 | 07:33 PM
nocooler's Avatar
I bought a digital angle finder today and spent the afternoon taking measurements.
Pinion angle is:
-1.0* Using the driveshaft angle to measure it
-2.4* Using the driveline angle to measure it
Then I measure the lower control arm angles....
DS = 4.7*
PS = 3.7*
This had me scratching my head.
Then I measured from the top of the tires to the bottom of the wheel arch.
DS = 3 5/8"
PS = 3"
So I pullled the drivers side spring - and then put it back in thinking it wasn't seated fully. Measured again - same results.
I then pulled the springs and swapped sides. Measured again - same results.
For grins I measured from the sway bar mounts to the floor (note - car is on 8" blocks all the way around).
DS 18"
PS 18"
This should confirm the floor is fairly level - I also measure from the floor to the beams in the ceiling that are level. The floor was less then 1/8" off on either side of the car.
I raised the passenger side until the gap in the wheel arch was the same as drivers side. The angles on the lower control arms were even @ 5.5* uphill to the car.
So either my body spring pockets are tweaked or my rearend is tweeked.
Now I need to find a way to lower the drivers side a half inch or raise the passenger side a half inch. I don't know if I can get away with the heater hose mod or not. I might need to chop the DS spring to get the ride height leveled. Maybe an air bag would be a simple fix.....
This would explain why the drivers side tire unloads or why the car goes right when it leaves.
Old Aug 15, 2009 | 08:27 PM
98blueSScamaro's Avatar
Pinion angle is:
DS = 4.7*
PS = 3.7*
DS = 3 5/8"
PS = 3"
DS 18"
PS 18"
wow nice but not nice find lol is the car twisted at all??? SFC????
Old Aug 15, 2009 | 09:04 PM
nocooler's Avatar
It's got SFC's that was the 1st thing I did.
Old Aug 15, 2009 | 09:21 PM
Wow well my car was ilittle off like you are talking about and the anti roll bar (drag bar) helped mine with the way you per load the bar the car sat 1/8th apart side to side .
Old Aug 15, 2009 | 10:08 PM
nocooler's Avatar
I'm going to see what I can do to try to get it leveled. It needs to be fixed before I go any further.
Then I can play with the rest of the suspension.
Anyone have any input on the pinion angles I measured?
I'm thinking that I'll adjust it down one more degree so it'll be -2.0 using the driveshaft method and -3.4 using the driveline method.
Old Aug 16, 2009 | 12:20 PM
nocooler's Avatar
I'm a retard - add a driver and it levels out.
Old Aug 16, 2009 | 12:38 PM
NHRAFORMULA00's Avatar
Just watched the video,the car rocks over to pass side.(watch the Spoiler).Get the BMR drag bar and front shocks.The BMR fits a little better than the Spohn in the area of the control ***** if you plan on going with double adj rear shocks later on.I have the Spohn and Strange single adj rear shocks ,this also works out OK.
Old Aug 16, 2009 | 12:41 PM
nocooler's Avatar
Thanks for the advice.
I was set on the Spohn bar - as I can bolt it in then weld it, and it's cheaper too. I'll have to reconsider.
Old Aug 17, 2009 | 02:37 PM
nocooler's Avatar
Single Adjustable QA1's w/300# springs are on the way for the front and a Spohn drag bar for the rear.
Hoping this will help.
I'll order the rear shocks in a month or 2.
Old Aug 29, 2009 | 05:44 PM
nocooler's Avatar
Everything is installed and adjusted.
I need to take the car for a ride and see how it does - and it's going the track on Wednesday, weather permitting.
The new shocks seem to have a lot more extension than the stockers.
Fingers crossed that it'll 60ft better and leave straight.
Old Sep 4, 2009 | 10:33 PM
nocooler's Avatar
Traction issues resolved.
I had issues with the 2-step and had to disable it.
I was chasing my tail all night.
At 1st the car spun leave at 5500rpm of the 2 step. The car backfired on every shift.
Then I thought I changed the 2-step to 5300 - droped the tires to 12 psi and got to the line - the 2-step was @ 3300rpm Car backfired every shift.
Track decided lay down some serious prep.
I disabled the 2-step - left at 5000rpm bogged
Left at 5500 - bogged
Left at 6199 (factory limiter) bogged - 1.72 60'
Packed up and called it a night.
I needed to add some air to the tires - as it was dead hooking.
Overall not a bad night. Time to add more power
Old Sep 4, 2009 | 10:56 PM
  #32
nocooler's Avatar
Video - this was 5500rpm
http://www.youtube.com/watch?v=KhL2bHNz2mc
Old Sep 5, 2009 | 11:42 AM
  #33
Mikey 97Z M6's Avatar
Good to hear your back on track, no pun intended. I'm going to be going through alot of those same procedures with mine before next weekend and this thread will help eliminate some issues.
Mike
