Drag Racing Tech
Chassis table leveling questions
Old Sep 13, 2009 | 01:36 AM
Blown06's Avatar
8 Second Truck Club
Default Chassis table leveling questions
When trying to set up the chassis/driveline on a race car using a chassis table what is considered "leveling the car"? Do you level based on frame rails, natural ride height, axle/spindle center line or what? Also, is it prefered to have the engine/transmission at zero degrees in the car once it is level?
Old Sep 13, 2009 | 03:13 PM
chvypwr31's Avatar
i level the rocker panels when doing chassis work
Old Sep 14, 2009 | 05:49 AM
jg04222's Avatar
I too used the rocker panels to level the car front to back. I measured at several different locations down the center of the car to get it level side to side. This doesn't mean that this is the correct method by any means, it was my first serious build (10 point, sfc's, etc) and I was kind of just using logic to do what I thought was right.
Old Sep 14, 2009 | 03:00 PM
ty_ty13's Avatar
7 Second Club
get a good line from you crank to your rear... straight as possilbe... we use rockers as well...
