Drag Racing Tech
Help with right gear ratio.....
Old Nov 30, 2003 | 11:14 AM
andy98Z's Avatar
Default Help with right gear ratio.....
I have 3.23s. Right now my car traps @ ~125. I went on the freeway yesterday and at 125 I am @ 5600 RPMS. My Peak Power was made around 6200. This was on Nittos though. Not sure wether Im going 26 or 28 ETs. Also, Im putting spray on it.
Not sure wether 3.42s or 3.73s in the new rear end.
Thanks, Andy
Old Nov 30, 2003 | 11:06 PM
andy98Z's Avatar
ttt...
Old Dec 1, 2003 | 09:41 AM
boomcase's Avatar
I dont think 342s is worth it for you, 373s is probable the way to go, but if your spraying it I would keep the 323s that will pull and pull on the spray.
Old Dec 3, 2003 | 10:25 AM
andy98Z's Avatar
I am buying a new rear end with either 3.42 option or 3.73, the shop that did my motor tells me to go 3.73s at lowest. I like streetability.
Old Dec 3, 2003 | 11:26 AM
Colonel's Avatar
What gear you need for the 1/4 has to do with a variety of things including...
Trap speed
Tire height
Power curve
Max RPM you want to turn the engine
Converter slippage with an automatic tranny
I'll assume that you want to cross the line at about 6400 on the bottle, 7% converter slippage, 26.2" tires, and 135 MPH across the line after the spray.
Ok, with 3.42s and 26.2" tires you'll be crossing the line at about 6367 which would be perfect. If you went to 28" tires and 3.73s then we're looking at about 6497. With 28s and 3.42s it would be about 5957.
Old Dec 4, 2003 | 03:21 PM
Navy David SS's Avatar
Colonel
Your numbers look right on. I am looking at some mod's to the SS this winter, is there a calculator out there to show best tires/rpm's/gears?
Thanks
David
Old Dec 4, 2003 | 03:36 PM
Colonel's Avatar
There are many. I use the one on Richmond's site.
