Drag Racing Tech
Grant steering wheel/quick disconnect
Old Oct 13, 2009 | 07:57 AM
sweetbmxrider's Avatar
Default Grant steering wheel/quick disconnect
looking to put in a quick disconnect for the grant steering wheel and am not sure if you can retain the horn.
this looks like it doesn't allow a horn
http://www.summitracing.com/parts/GRT-3021/?image=large
http://www.summitracing.com/parts/GRT-3001/
am i right? will i still need a hub installation kit?
thanks for the time guys
Old Oct 13, 2009 | 08:46 AM
ty_ty13's Avatar
7 Second Club
wont work.... put a push button/toggle somewhere in the car for the horn
Old Oct 13, 2009 | 11:46 AM
alright got ya. do you know if i only need that quick disconnect hub to install the grant wheel or will i need their installation kit as well? i think its just an adapter for the three screws to thread into and the factory nut presses it onto the column.
thanks
Old Oct 13, 2009 | 01:07 PM
ty_ty13's Avatar
7 Second Club
i had to weld mine on...
Old Oct 13, 2009 | 01:33 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The way the wires run through the steering column and out of the piece that retains the steering wheel would make impossible to disconnect the steering wheel. You'd have to drill a hole in it and then add disconnect fittings for the wires so you could remove the steering wheel. I'd honestly toss the whole horn assembly in the trash as I have done in my 93.
Old Oct 13, 2009 | 02:55 PM
hahaha alright. i guess i'll just put a momentary switch on the dash.
