Drag Racing Tech
Moser 12mm wheel studs?
Old Dec 5, 2003 | 03:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Moser 12mm wheel studs?
I see two 12mm part numbes for Moser press-in studs, one is 1.5?" and the other is 2.5", anyone used them yet? I need some for the front, I am assuming that 2.5" ones might work?
PSJ
Old Dec 5, 2003 | 03:54 PM
xaon's Avatar
not sure about the moser studs... I bought a set of ARP 2.5" press-in studs, and running 5/16" spacers up front with my prostars, they still weren't long enough to pass tech.
Old Dec 5, 2003 | 04:52 PM
LS1x2's Avatar
Formerly 4mulaJoe
With a 5/16" spacer up front and 15x3.5" pro stars these come flush with the holes in the wheels. They don't stick out past the lug.
Old Dec 5, 2003 | 06:15 PM
Camaroholic's Avatar
I bought a set of the longer Moser studs to stick in my 12-bolt axles. It originally came with the shorter ones.
The shorter ones are low quality (IMO). They'll gall after a while of changing wheels. They're standard steel material.
The longer ones are *exactly* like the ARP studs (I bought a set of those too), except the longer Moser studs are black in color (unlike the ARP's which have a goldish appearance). Otherwise, they look the same in every dimension.
On my Bogarts, the longer / ARP studs are perfect on the back, but maybe .1" short up front (if you're talking NHRA-legal-to-the-digits). On the back, they do protrude in to the hex threaded portion (past the washer) by the diameter of the stud. On the front, they stick past the washer, but just an ooch short of a stud diameter.
-Andrew
Old Dec 5, 2003 | 06:22 PM
Navy David SS's Avatar
PSJ
I got my ARP set from ThunderRacing. Perfect fit. My Moser Rear long studs have some rust from the few rains it has seen. The front ARP's are still perfect.
David
Old Dec 5, 2003 | 06:32 PM
LS1Tech Co-Founder
Andrew I have black long studs in back you want to sell those Mosers?
Old Dec 5, 2003 | 07:16 PM
I don't have 'em anymore, I had a local shop swap 'em while I was out of town. They trashed 'em, AFAIK.
