Drag Racing Tech
body seperation while staged
Old Nov 29, 2009 | 10:21 PM
TJ's Avatar
TJ
Default body seperation while staged
this a good or bad thing?
the higher RPM i footbrake the car, the more seperation i get in the rear.
car hooks great, just wondering if i can adjust something to get it out of a bind.
Old Nov 30, 2009 | 08:23 AM
1badzo's Avatar
Stop making so much power that should fix it.
Old Nov 30, 2009 | 08:48 AM
mrdragster1970's Avatar
6 & 8 Second Club
If it hooks, don't sweat it. You might get to the point where you will need to do something.
A lot of cars need that hit to plant, and then you will need a brake or higher stall.
I'm a little more power so it's not the exact same, but if I load mine up.
It blows the tires off instantly. I need the 1st hit to drive the tires down.
Good luck.
Old Nov 30, 2009 | 09:40 AM
tee-boy's Avatar
Default dfdfdfdf
I do the same w/ my car; don't know how to get around it with footbraking. My ET/60's would suffer if I didn't stall up the converter (not that it matters b/c I bracket race). The benefit to me is quicker RT due to suspension is pre-loaded. With my stall speed and on the foot brake, my car is dialed in to the 3rd amber light. If I ever go up on the stall speed, I'll just have to stage further away from the timer light in order to keep car dialed on the 3rd amber.
Old Nov 30, 2009 | 11:15 AM
JL ws-6's Avatar
Race your car!
The rear should seperate from the body, if you are seeing that when you're footbraking up, and the car hooks that's fine.
You could try lowering teh leave rpm, it may help, may not. if the car was spinning initially, I'd try leaving a little lower, so the tires get more of an initial hit to plant them, but if it's hooking with what you're doing, it's probably o.k.
You could try stiffening the rear shocks a little, probably won't stop it, but it may decrease it a little... again could be beneficial, may not be though.
Old Nov 30, 2009 | 07:59 PM
studderin's Avatar
is this the same as anti-sqawt, just when you footbraking a auto?
Old Nov 30, 2009 | 10:02 PM
TJ's Avatar
TJ
Good luck.
the car will footbrake 4900-5000, so i dont know if anymore stall would benefit.
my concern is if the car will react quicker if the rear isnt bound up during staging.
rear shocks are on 7 slicks. i usually run them at 3-4 on a lesser track.
i kept turning them up sunday and it kept on hooking.
car still seperates even with the shocks on full loose.
Old Dec 1, 2009 | 07:13 AM
6 & 8 Second Club
Maybe I'm saying it wrong, but like I said, my car needs that hit, or flash.
I needed to launch at the lowest RPM possible without the engine hesitating.
It did not like being loaded up. I really needed the chassis to do what it's made for.
If I did have to much load, it did not drive the tire down enough and spun.
With the *** already up in the air, you are not getting the travel some cars need.
I still say, if it's working, don't touch it. If you add power and see a change, then you try something.
Old Dec 1, 2009 | 10:13 AM
Phil99vette's Avatar
7 Second Club
Usually it will seperate on the footbrake, settle when you jump on the transbrake and seperate again once you release the T-brake.
Old Dec 1, 2009 | 10:37 AM
913MOTOR's Avatar
Can someone explain what is being talked about, im just getting into drag racing and not understanding this terminology.
Old Dec 1, 2009 | 11:03 AM
tee-boy's Avatar
In order to get rid of it, minimize it, or change it... You need to change the rear suspension mounting points (up or down or front to back).
Old Dec 1, 2009 | 01:29 PM
6 & 8 Second Club
They are talking about launching with your foot on the brakes, instead of the clutch or transbrake.
With the tires locked, when you give it throttle, the car tries to drive against the brakes and loads up.
With a clutch or transbrake, there is no force being applied to the slicks, & chassis.
Old Dec 1, 2009 | 02:55 PM
tee-boy's Avatar
Default hjkljhkj
that's right. there is no load w/ a transbrake since the drive isn't engaged with the load - atleast while the finger is on the button. Therefore, the body can't load against the rear end via the suspension links.
Old Dec 1, 2009 | 04:31 PM
913MOTOR's Avatar
I see understand now, ive always known it as loading the suspension. Never had to worry about that with FWDs.
Old Dec 1, 2009 | 04:39 PM
tee-boy's Avatar
Default fwd dd
Is that a front wheel or a four wheel drive?
Old Dec 1, 2009 | 08:26 PM
913MOTOR's Avatar
front wheel drive, i daily drove and drag'd a grand prix GTP with some work done to it.
Old Dec 1, 2009 | 11:30 PM
studderin's Avatar
gtps suck
Old Dec 2, 2009 | 10:24 AM
913MOTOR's Avatar
Why because my 4000lb four door kept up with bolt on LS1s?
Old Dec 2, 2009 | 11:12 AM
JFM-jr's Avatar
Here is a great thread I had saved on this topic.
https://ls1tech.com/forums/drag-raci...ear-squat.html
Old Dec 2, 2009 | 04:18 PM
Minshall's Avatar
Anti squat is where its at. I foot brake my car up to 3800 when i launch. I bet the rear of the car raises up a good 2 to 3 inches. But if you look at my 60's they speak for themselves. A consistent 1.43-1.42 car every launch.
http://www.youtube.com/watch?v=3xLr5SILS_s
