light weight hood for trans am?
Wipers will have to go, as it covers the entire cowl up to the windshield, and it's a pin on like the joe van o. I can tell you, it's about 14 lbs before trimming/painting, so figre 15 with paint I'd guess after being mounted. Stock ws6 hood when I took mine off was like 47 lbs if I remember right, then figure the release cable, handle, hood latches, hood hinges, hood shocks, all that stuff that gets to go. Granted you'll need 5 lbs in rails, but you're probably losing another 5 lbs in all that other stuff that goes away.
Yeah, get back to me after actually using those 1/4 turns. They ******* suck. My buddy has 4 small pins on his WS6 and it looks 100X better than any rail setup I've seen.
Or if you wanna be really slick get the aerocatch latches. 4 of those will hold anything and you can lock them.
The Dzus fastners are fine as long as you have a solid mount on the car, if the mount's are little tabs that can move around I agree 100% they are a nightmare, but on cars I've worked on that had them done right, they're fine.
