Drag Racing Tech
Twisted splines inside of front yoke???
Old Jun 17, 2011 | 06:36 AM
SlickVert's Avatar
I went with a Viper output shaft and it has a much larger yoke.
Old Jun 17, 2011 | 02:23 PM
Nitroused383's Avatar
Thats not an option for me at the moment. What 27 spline slip yoke is holding up for 6 speed guys?
Old Jun 19, 2011 | 10:28 PM
Gary Z's Avatar
I have a PST shaft with a Spicer 1350 yoke that I just checked after reading this thread. Mine still slides in and out smoothly after 200 or so 6000+ rpm launches. Obviously, twisted splines can be caused by a drive shaft that is too short which reduces spline engagement.
Old Jun 20, 2011 | 07:43 AM
blue99fbody's Avatar
I've twisted 2 stock spline spicer 1350s and one 30 spline spicer. I now have a strange 30 spline in it and last I checked it was ok.
Old Jun 20, 2011 | 09:02 PM
1BADAIR's Avatar
my mark william billet is still perfect
Old Jun 21, 2011 | 07:19 AM
samdogmx's Avatar
It's your clutch. I had no problems last year with my spec 2 clutch. Switched to a monster & now I have 2 twisted slip yokes. I'm giving up & switching to a auto now.
Old Jun 21, 2011 | 07:31 AM
I had a LS7 clutch I highly doubt that was the problem. I did dump it at 6800-7000 rpm's a few times though. I asked midwest chassis what slip yoke they recommend and they said there is no yoke guaranteed to last on a 6 speed with slicks, but they have had the best luck with the strange chromemoly one. This is the one I went with http://www.jegs.com/i/Strange+Engine...U1667/10002/-1
Old Jun 21, 2011 | 08:02 AM
jmm98LS1's Avatar
but they have had the best luck with the strange chromemoly one. [/url]
I twisted one of those last year after just a few hard launches on slicks, but got another one just like it and it's been fine for over a year now. *fingers crossed*
Old Jun 21, 2011 | 05:48 PM
studderin's Avatar
my $19 spicer was fine.
Old Jul 1, 2011 | 11:12 AM
John02SS's Avatar
I have twisted up a yoke and broke a output at different times. When the car was a 6 speed still it had a Viper Outshaft and Mark Williams yoke. No more issues at all! Really nice stuff. On the TH400, I also run a Mark Williams shaft and yoke.
I have the stock splined T56 Strange billet yoke if you need one cheap. It is like new and just collecting dust. PM if your interested.
Old Jul 1, 2011 | 12:23 PM
Mikey 97Z M6's Avatar
I broke a forged spicer unit and then switched to a billet Moser for a powerglide. Think it was around 160.00 if memory serves... Same dimensions and spline count as the stock T56 and has removable caps for easy U-joint service. Haven't been to the track with it much since replacing it so I can't really comment on how it's holding up.
Mike
Old Jul 1, 2011 | 12:37 PM
  #32
nocooler's Avatar
Add me to the club - looking at options. I'm pretty sure it's a strange 1350 unit that I twisted.
Old Jul 1, 2011 | 02:26 PM
  #33
I don't plan to dump the clutch any more. A fast smooth slip from now on, tired of ******* **** up. We will see how it holds up to a 5500 rpm launch on 6lbs of boost tonight.
Old Jul 1, 2011 | 09:23 PM
  #34
studderin's Avatar
My spricer was not forged or any heat treat. It was for some OD auto it was longer and had so spines for the 1st 3.4 was just smooth for a Oring or something I was told? Just cut it off and deburred it with a cutoff wheel went low 1.4s wheels up and 100's of 1.5 at 6500. went thu 3 clutchs, twsited 35spine S60 axles, broke a true trac, 3 sets of Drs. I was something like $17.80 . I have no idea how its fine.
http://i2.photobucket.com/albums/y11...n/IMG_5020.jpg
http://i2.photobucket.com/albums/y11...n/IMG_5018.jpg
http://i2.photobucket.com/albums/y11...n/IMG_5075.jpg
http://i2.photobucket.com/albums/y11...n/IMG_5077.jpg
I went to the moser with the billet cap too after some guys broke there slip yoke, and it did damage to the rear end too they didnt know at 1st. So cost them like 1,500 2,500 all form the slip yoke
Old Jul 1, 2011 | 11:29 PM
  #35
boss79z's Avatar
In the same boat, and went to the strange chromoly as well.
Old Jul 2, 2011 | 12:22 AM
  #36
Zmg00camaross's Avatar
Anyone have a part # for the badass mark williams yoke?
Old Jul 2, 2011 | 10:26 AM
  #37
I was under the impression that all the Spicer units were forged? How is the Moser unit holding up for ya?
Mike
Old Jul 2, 2011 | 10:28 AM
  #38
So how'd it go last night?
Mike
Old Jul 2, 2011 | 05:04 PM
  #39
I removed my bump stops and did the slip yoke. Best 60' was a 1.62 but I only made 3 passes. Thats a big improvement over my 1.85-1.88's I was cutting. I'm having some issues above 5600 rpm sputtering and popping so I was just concentrating on the launch. I did run 1 full pass at the end of the night, 11.1 @ 127 with a 1.75 60' blowing the tires off. Not too bad for 26" tall tires, 3.50 gears, lowered slp bilsteins and springs with stock lower control arms Looked like 3100' DA.
Old Jul 2, 2011 | 06:59 PM
  #40
ls2 bait's Avatar
Twisted 3 and shattered 2 spicers. Mark williams now w no issues.
