Question on 15" wheels on stock rear Will 15" wheels fit on a stock rear end of a 2002 Camaro? If not what modifications have to be made for brake Caliper clearance? Looking to buy new rims for drag slicks and options are limited. |
It depends on what rims you want and what size. So bolt right up and some require grinding the calipers |
15" X 8" wheels is what i'm trying to find out if this size will fit before i place an order.:bang: |
What brand? Welds(summit and jegs knock offs) dont fit, you have to grind a lot Bogarts are pretty much a direct fit but they are custom made |
we have 15x10 Billet Specialties that are a direct fit with stock brakes. |
Centerline Convo Pros fit with no grinding on the rear, but I think mine are 15X10. |
Thanks for the info. I should have posted this morning instead of wasting all day on the phone and Internet trying to get the right info. With that much backspace and 10" wide it doesn't create clearence problems on the back side? Don't guess it's offered in 15x8?:confused: |
Thanks for the info. I should have posted this morning instead of wasting all day on the phone and Internet trying to get the right info. With that much backspace and 10" wide it doesn't create clearence problems on the back side? Don't guess it's offered in 15x8? |
THe Billet 15x10 are an F Body specific wheel. They will fit no problem. |
No clearance problems with mine. 26X10.5 slick outside edge sits right where my 315 35 17s fit on my 17X11 Torque Thrust II wheels. |
The usual backspacing you want is for a 15"x8" 5.5 and the 15x10 you want 7.5 |
centerline also offers 15x9 6.5 backspace in several styles that fit with only light caliper grinding. |
© 2024 MH Sub I, LLC dba Internet Brands
