Drag Racing Tech
8.5@91(1/8),What is wrong with this?
Old Dec 28, 2003 | 09:44 AM
SSZSLP's Avatar
Default 8.5@91(1/8),What is wrong with this?
Shouldn't the et be better than this? ,60 ft. 2.2-2.3 range,would slicks be my "cure"??00 SS,6spd,spec stg 3,lid,lm,50-80 shot yields the same results!
Old Dec 28, 2003 | 12:03 PM
NastyWS6's Avatar
Your 60' is killing your ET I will say that much, slicks would definitely help
Old Dec 28, 2003 | 12:08 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
91 mph in the 1/8 will translate to a good 11.70-11.80 pass easily if you can hook up all the power! Get some sticky tires and enjoy a lower et!
Old Dec 28, 2003 | 02:17 PM
SSZSLP's Avatar
Thanks for your input,Villan I see your running spotrsman pros,I ususally dont see them anymore,must work decent if your at 1.93,and Nasty what are you running to get 1.57??I will be getting seperate wheels to mount on,recommendations??
Old Dec 28, 2003 | 04:42 PM
7 Second Club
my formula is pretty much a stocker with the minor bolt-ons listed, and the sportsman pros are on 16 x 8 take-off rims from slp. I like the sportsman pros better than drag radials b/c they have a decent sidewall and tread depth to hook more consistent. A friend has em on a 95 formula with bolt-ons, a 3400 stall jw convertor and 3.73 gears and he cuts 1.70s on them consistently and gets 10,000+ miles and about 200 runs from a set. They work great for daily driving, including rain! I use M/T ET Streets on my Nova, once you get into the 1.6 60 foot range, a dot slick or drag slick should be your tire of choice.
Good luck!
Derek
Old Dec 28, 2003 | 05:24 PM
DeepBlueZ's Avatar
i do between 88 and 89 mph in the 1/8th and run 7.60-7.70s....thats good for a 12.10 pass.....91 mph in the 1/8th is definitely and 11 second pass! 1.8th mile should be in the 7.30-7.50 range. 2.3 60 foot is destroying your et! good sticky tires will make your car feel like a whole different animal.
Old Dec 29, 2003 | 12:51 PM
NastyWS6's Avatar
I was running 26x11.5x16 ET Streets for the 1.57.
Old Dec 30, 2003 | 02:15 PM
SSZSLP's Avatar
I greatly appreciate all of your responses,no wonder, I figured something was NOT right with the et/mph equation,man I would slap happy with a mid to high 7 second pass,only problem than would be,no matter how fast we go,it is still NEVER fast enough!Thanks again for the help.
Old Dec 30, 2003 | 03:26 PM
DeepBlueZ's Avatar
no, thats true. It's never fast enough! good luck!
