Winch Mounts In Trailers?
Are the cross beams strong enough? I figured 4,000lbs for my car (to be safe)
My winch is rated to 8,500lbs and 17,000lbs when using a pulley.
It's pretty strong... haven't tested it out yet but after inspection I can't see it being a problem
Unless the thing is in gear, it does not take much load to pull it in.
I installed the winch myself, and I mounted it right to the wood floor.
I did use fender washers, and I had no issues ever.
A backing plate would probably be smarter, I was in a hurry, as usual.
I have a ton of buddies that have the winch on the side, and they use a clip on pulley to the tie down.
A decent all metal pulley will be plenty, you really don't need some massive piece.
Good luck, you are going to love the new enclosed.
Everday I walk out and see my enclosed I get a smile on my face!
Plan to get it all loaded up this weekend.
Now the "small" detail of getting the car back together and running again....I still have 2 weeks until opening day...that's plenty of time to put it together, run my nitrous, weight removal, 5 point, dash, switches, switch to an auto...on and on
Late nights to come!
I used some 1/8" plate about 9" square for the d-rings.
I might have been lazy with the winch, but I did not want my baby moving or coming loose.
Just a tip, use stainless. I used standard bolts and stainless washers & nuts.
4-5 years after I got it I was under there fixing some wiring that a flat tire ripped up and the bolts were nasty,
and the nuts were like new.
I keep my trailer in the garage, and very rarely got caught in the rain & they were still rusted up bad.
But I'll definately re-enforce the D ring for the winch.
My current winch is a 5000# Superwinch, which is overkill, but, after I sold my old trailer with a 3500# Superwinch, still usually overkill, the 5000# was on sale for the same price as the 3500#. Dave
