1.30 60ft but...
I took the air bag out because I thought I would not need one with the anti-roll bar.
Live and learn I guess!
Tom
no slider so susp binds, so hes got to fix afew things ,like i said its repairable but it sucks to go through all that and it not work
Tom
at least put one air bag in the right side. just my .02 Hotchkis-subframes, panhard rod
BMR adj. c-moly LCA's
Stock springs
QA1 12 way's
Air bag in right rear spring
Hotchkis rear swaybar (basically stock)
Front:
QA1 "R-Series" shocks w/QA1 springs
stock k-member, control arms
Best 60 ft 1.31 consistent 1.32-1.35 No trans brake 346 w/ NOS
See my launch video down the page.
https://ls1tech.com/forums/drag-racing-tech/123805-1-42-60ft-back-tires-my-wheelstand-video.html
what psi are you running your tires at? im running 28x13.5's with just about the same suspention setup as most of these guys and i can seem to hook better than low 1.5's. but then again i have only had 1 day at a track rental to get the feel for the car. next time out will be with a th400 with a brake.
It shows that the anti roll bar is simply floating around, there is nothing to hold it in place, which meand it is not doing its job. Think about it this way. If you pulled your bushing out of your front end, and drove you car around, you might notice the front end was a bit loose. In this case, it can make the anti-roll much less efective or optimal than it could be IMHO.
Front to back is a different story and I just need to keep tweaking the shocks until it stays down.
Taner has the best setup I have seen so far. All BMR gear AFAIK and his car hooks and goes straight. With the sixspeed launching on spray it is sick. 1.29 I think?
Good luck, with all the BMR gear and Airbag you should be 1.2's no problem
Wade ran all BMR in the Z28 as well.
