Drag Racing Tech
another trutrac fail
Old Apr 18, 2010 | 05:40 PM
subhumanzz's Avatar
Default another trutrac fail
finally got around to tearing the diff apart and this is what i found. m6 car making 500, launching at 6500. had 4.11's in it, now i have a spool and 4.56's. seems much better but havent got to the track yet as i am waiting on front shocks and springs to get here.
Old Apr 18, 2010 | 08:21 PM
Bill00Formula's Avatar
That sucks! Might be bad news for me as well. I recently broke my 12 bolt and they are replacing my auburn w/ a truetrac. the grears (4.11s) seem to be fine. My car probably makes 550 rwhp but I don't launch as hard you.
Old Apr 18, 2010 | 08:30 PM
fuel's Avatar
yah my true trac didnt like the wheelies
Old Apr 18, 2010 | 08:32 PM
Carter01's Avatar
Been there, done that, now I have a spool as well. Good Choice!
Old Apr 18, 2010 | 08:42 PM
flyinZ's Avatar
Dumb question, but what makes the Tru-Trac so weak? Compared to other posi units? This isn't the first time, I've seen a TT fail.
Old Apr 18, 2010 | 09:02 PM
heavy6.0's Avatar
we have installed a few of these in car over 500 to the tires and never a had failure (knock on wood) we are suspecting that there are some small contaminents getting into the gears causing them to self destruct. just a thought.
Old Apr 18, 2010 | 10:51 PM
Carter01's Avatar
From what I've seen thus far it's mainly the 6sp cars that's breaking them due to the hard hit of the manual. It seems that the auto is a little less stressful on the TT. If you search you will find many posts very similar. Unfortunately I searched a little too late, hence why I have a spool today. I can't complain though because the Sponsor I bought mine from made it good but I would not recommend a TT to anyone. As far as contaminents causing the failures, I'm sure it's possible but after mine was torn apart this theory was not mentioned by the company that built the rearend.
Old Apr 19, 2010 | 12:06 AM
studderin's Avatar
<3 my spool
TT is good for a jeep or somthing you climb rocks at 10mph. Not drag racing, 6500 clutch dumps.
what rearend do you have? what gears with the TT, how is the new setup?
Old Apr 19, 2010 | 02:42 AM
Zmg00camaross's Avatar
Cant wait to be in the destroyed tru trac club this year.
Old Apr 19, 2010 | 04:37 AM
subhumanzz's Avatar
moser 9", had 4.11 with the tt. now its a spool and 4.56's and its great so far.
Old Apr 19, 2010 | 06:40 AM
JL ws-6's Avatar
Race your car!
That tru-crap diff is the worst thing to ever come out. Makes a 12 bolt/S60/9 inch worse then a 10 bolt is in the reliability department.
I've seen 350 rwhp cars kick those things out with a stick... just like a 10 bolt.
tru-crap= fail.
Old Apr 19, 2010 | 06:48 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I saw too many failures when I was at Exotic Performance Plus, so I took all the Truetrac's off the website. The failures started happening after Eaton took over the Truetrac, the Truetrac use to be a very dependable unit for under 600 rwhp. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 19, 2010 | 10:48 AM
AChotrod's Avatar
I be replacing mine with a spool soon. Still works fine but Im trying to loose some weight as well as gain strength.
Old Apr 19, 2010 | 11:41 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I have 2 broken ones. I am now inclined to tear apart my 1st one and take pics.
Old Apr 19, 2010 | 11:42 AM
Internet Mechanic
I had both the Original and newer Eaton based unit. Both Broken.
It was the design.
Old Apr 19, 2010 | 11:58 AM
AChotrod's Avatar
So much much does it cost to swap over to a spool?
Old Apr 19, 2010 | 01:08 PM
Internet Mechanic
Cost spool + Local Labor + Fluids = Cheaper then a standard Diff.
I think I saw on Moser's Website for a steel full spool being like 200ish. The diff alone when I got mine was over 500, I think it was near 600.
Old Apr 19, 2010 | 04:08 PM
camz28arro's Avatar
3000rpm+ clutch dumps kill them
<3 my spool
Not even good for a jeep, friend broke his rear Trutrac in his 8.5" lifted cherokee, It was an A4 too but did have 4.11s and a 4.6L with 300tq, maybe 4000lbs. Now he has air lockers.
Old Apr 19, 2010 | 04:44 PM
1nastyss's Avatar
damn, i replaced mine with a spool last year, glad i did, and i got some descent cash for the TT also
Old Apr 19, 2010 | 07:10 PM
Duffster's Avatar
Like BlackScreaminMachine, I've HAD two broken ones... both went into trash pretty quickly. . .
