Easy street car weight reduction
already is
no spare/jack
no bumper supports
no washer fluid/pump/reseviour
no air system
no back seats
thinking of doing soon:
delete ac/heat
p/s
is it possible to:
pull up the carpet and scrape out the sound deadening material?
remove anything in the engine bay?
whats required in deleteing the asr
my abs already doesnt work because of the difference in sizze of my tires so how hard/what is required for deleting teh abs?
Plus with only having a driver's seat and dash on the inside it was nowhere near worth the ride or effort to gut the car. I only gained about .25 and 2 mph. I also pulled the bumper support, sway bar, and air pump. I can't think of anything else at the moment.
When you decide to turn the corner and make it a track only car then go all out. For a street car I'd rather put a little more money in and try to get more power out of it.
I'm gunna get rid of ABS and the power brakes, power steering, front supports, and anything else I can find, included un needed plastic peices, any un used metal brackets, and anything else I can find!
I am going to get rid of the factory carpet and sound deadening material but I'm going to dynamat the car and add the speed inc lightweight carpet. I already have the K-member and other goodies, just need some lightweight breaks.
I'm going for a max effort with the motor I have... which is a solir rollered 408 w/ meaux stage 3 ls6s. I've gotta shed weight so I can add it back with a cage and the 9" rear.
The search function has been revised quite a bit over the time the board has been around. It's not there for people to say "use the search function, dumbass." It's there to help members out instead of creating new threads where they may not get much response b/c the subject has been discussed before and some might not want to re-type their input again.
Derek
My car has only gotten slightly louder after this. It's noticeable, but not crazy
https://ls1tech.com/forums/drag-raci...tweight+carpet
