Drag Racing Tech
Burnout question
Old Jan 14, 2004 | 04:25 PM
ssdungeon's Avatar
Default Burnout question
OK installing the linelock this weekend. When I race I run ET streets... I have been toasting tires launching at 3 grand since day 1. I was told it was from not heating the tires enough, well we will see.
"On the street" We have a lot of land down here in the country..... should I pour water on the street to do a burnout? We race on a blacktop road that has so many tire marks it may as well be a track its off a bridge so there is concrete there.
Thanks,
Old Jan 15, 2004 | 10:59 AM
Assassin's Avatar
with the line lock installed burnouts are going to be stupid easy with any size tire, just line lock it and do a burnout for about 5 good seconds, that should be enough to heat them to hook great, run around 12 psi also,
Old Jan 15, 2004 | 12:27 PM
bad2000ss's Avatar
If possible burnout in 2nd gear, gets the tires spinning faster.
Old Jan 15, 2004 | 02:40 PM
ssdungeon's Avatar
Thanks guys. I figured the water would heat them easier and put less strain on the drivetrain. I have never had a line lock before and just did not know.
Old Jan 18, 2004 | 09:26 PM
BBADWS6's Avatar
use VHT, smells good and works like glue
Old Jan 18, 2004 | 09:27 PM
ssdungeon's Avatar
Whats VHT
