Drag Racing Tech
Cloyes ?
Old Aug 14, 2010 | 05:04 PM
LSPerformance's Avatar
Default Cloyes ?
Anyone using Cloyes Hex single row 9-3153-A timing set on solid roller (550 lbs. over the nose) stuff?, if so, any issues?
Old Aug 14, 2010 | 07:34 PM
Shawn @ VA Speed's Avatar
we use cloyes single roller chain with 800lbs on the nose.same chain 2 seasons at 8000+ rpm with no issues.
Old Aug 14, 2010 | 08:56 PM
Shawn, you are using Cloyes part number 9-3153-A in that application?
Or is it part number 9-3153-AL?
Thanks
Old Aug 14, 2010 | 09:15 PM
Thanks
i believe cloyes discontinued the 3153 series and replaced it with the 3158
we use the 9-3158-a which is the std chain with no issues
the 9-3158-az has the c5r style chain.We use the z style chain on raised cam block only because thats the only one available.
Old Aug 14, 2010 | 10:29 PM
The box says 9-3153-a, but the cam sprocket looks like what is in the 9-3158-a set. Since the 9-3158-a will work the same, looks like they did just that.
Thanks for your help.
Rick
