Mounting BCM after hvac delete?
Hey guys I finally got around to deleting the hvac/evap system and passenger airbag and I was wondering how everyone was mounting the BCM box after everything else is gone? I figured I'd just zip tie it up somewhere but I can't figure out where to put it. Pics would be helpful, thanks.
I used some GOOD double sided tape and stuck it to the HVAC deletel plate. You can also do the same with it to the back of the glove box, I've seen a couple people do that.
Or, zip tie it up to the harness that is running across the dash, that will work too.
i had the same question when i did mine and this it what i did. double sided sticky tape to the hvac delete plate
