Need help installing front coil-over’s (Question)
As u know, the stock spring sits against the upper A-arm mount bushing; while with the Strange shocks the spring mounts on the shock itself. Just before I fit the new coil-overs back in I need to clarify some doubts;
-Is there any modification required to the upper A-arm mount bushing, or do I just put the shock rod/stud through the bushing washer and tight it down?
any tips info would be appreciated
are you useing stock coilds, bmr makes a lower spring cup to fit them. or you can cut/grind the stock lower mount to fit oevr the shocks. i did that, check my build thread i have some pics of the parts on my car. and a diagram on what to do the the stock lower mount to use the stock coils.
but no i have aftermarket 14"/2.5"ID Hypercoil springs and bolt-in drag shocks. im only worried about the upper shock mount
thanks a lot
