Door Bar Removal Thread
im going to be removing my door bars next week, but want to go a step further. the car is track only car with cage. is it possible to cut out the inside door skin? will it have any ill effect? and how would i go about removing the window motor/regulator, but leaving the window up...is it possible?
I couldn't get any wrenches on those bolts, and don't have a welder to make a tool. Any other options? Anyone able to just cut everything out with a dremel? I have no air tools either.
Someone said the doors would be easier to close? I didn't notice that. How can that be?
For a light-weight-swap-out race set.
I also snatched up a rear hatch in the matching color, got that for $30 too. Prepping it for SpeedGlass.
Since the doors were off, it was easier to remove the bars, but still took a while since I didn't have a ratcheting head tool. I had a ground-down swivel socket wrench. No room to use the tool for complete extraction. I put a 1/4 socket on it when the wrench wouldn't fit anymore. Then I just turn the socket with my fingers.
BTW, I've see the holes drilled in the back of the doors, but you could drill a hole in the flat bottom part of the door. From Memory, I used a 2 inch hole saw, and located a spot that was completely on the flat bottom, but right up to the edge of the door that started to curve up. Then I moved over towards the outer side of the door, against the same edge. Finagled the bar around, and it also required that the bar be rotated with the tongue down. It was that close to not having room. The bar will need to be moved around a bit to the upper-most front corner and then the back of the bar it will come out through the bottom drill hole tongue down, and the hole will remain out of sight.
or you could remove the tire and wheel well, etc as in a previous post.
Jay Johnson
So far I am able to only get out the one 10mm closest to the door latch using my smallest 1/4" drive. The next one in I could only loosen, and the two at the front near the hinge I still can't get any wrench or ratchet on them. I hope this cutting and bending works. I even spent $25 at sears getting a swivel socket set thinking I could use them at 90deg bend but even that's too fat
