Saving weight by using Mr. RotoZip
Want to get 15 lbs out of the car for about 15 bucks? Rip everything out of the interior, get a couple wire wheel's and a drill, and remove all the seam sealer out of the inside of the car. be ready for a big mess, but it's about 15 lbs of crap. Just finished doing mine yesterday, and I still have to get a bunch out that's behind the cage, when that gets redone.
Don't forget to repaint the floor when you are done, since you're taking it to bare metal.
There goes 15 lbs.
There goes 15 lbs.
BUT one thing he does is make sure that strength is put back in key points to help keep the car safe. Saving 10 pounds but making the car hazardous is no savings to me.
I still have some left in my car where I couldn't get to it because the 10 pt was in the way... I took all the stuff that was on the floor (my garage is kept clean, so what I swept up is pretty accurate) along with what I sucked out with the shop vac and put it all in a garbage bag.... and weighed said bag.
12 lbs give or take a little, as my home scale goes by full lb increments.
It was a nightmare getting it out. Took 3 wire wheel's to do, and probably about 7 hours of my life, but to me, being I'm on no time schedule it was worth it.
Once I have the front end off I'll get the rest of it out, and once the cage is cut out to redo that, I'll get what's left inside the car. It's a pita, but it weigh's a good bit.
