adj. front suspension / alignment help needed..
Right now the cars got new k-member and lower adj lca's - the lca's have been set to factory length prior to installing but are loose in the kmember. I'd like to get the cambe caster and toe close, do you guys have any tips on setting camber/caster in my garage, I've got a laser level n can mark out the floor and use plumb bob etc. I just wanna get it close. After that ill take the car to my buddies shop and get it on the rack to set it perfect to madman specs.
Thanks,
Nick
thanks for the help tho
you can get the rear end sqare with the plum bob, a tape, and strait edges. always got it really good that way.
