Drag Racing Tech
Which battery disconnect to use?
Old Feb 3, 2004 | 10:28 AM
LOnSLO's Avatar
Default Which battery disconnect to use?
Are you guys using the Moroso push/pull switch? NHRA rules do mandate a push/pull type, right?
Old Feb 3, 2004 | 05:16 PM
DERTY's Avatar
The Bull
You can use a push pull or a switch that turns on and off by rotating it. Moroso makes both, it's the same switch. One has a **** with the switch. The other comes with a lever and attachement for it. You can also get a nice unit from Flaming River. Comes complete with the bracket and levers. I think Moroso sells the bracket extra, but I'm not sure.
Old Feb 3, 2004 | 06:54 PM
TApimp's Avatar
we use a push pull type from moroso
