tow vehicle
My buddy gets 18-20mpg with his 04.5 Dmax towing a car.
I went away from diesel a few years ago because I didn't think I had a need for it anymore. It took me two weeks to realize I will never be without a diesel again.
I've probably put around 5k miles on it this year towing my open Featherlite trailer (1300ish lbs) with my 2975lb Camaro. It's much better than my 04 1500 5.3 Silverado. The new 6 speed makes towing much easier, and it doesn't hunt for gears nearly as much as the 04 did.
Granted, I haven't done anything to the truck, it has all the new 2008 mandated emmissions crap, it can be deleted, but to do that you have to use a tuner, void the 300K warrenty on the motor, and put it back to stock every other year here in CT to get it thru emmissions.... I haven't had any emmissions related probelms with it, and I think as long as you drive it hard enough, you won't have any. I know there's a good 2 to 4 mpg better mileage with it all off... I just don't want the headache of putting it all back every other year. The new chevy's and new ford's also have all that crap on them, and would be the same deal, have to put it back to stock every other year if you have emmissions to deal with. The comptuer's, are now pretty tight (can't really crack them like you used to be able to) so it's not something you can just trick as easy as you could in the past. Plus, they all save a log now with ever change you make, so if you do something, the dealer will be able to tell, if you try to warrenty something.
Hope this helps.
300,000 mile warranty from Cummins. Is that true? I have heard 100k. My next truck will be a 2500 diesel just not sure between the duramaxx or the cummins. But if the cummins has a 300k warranty that will make the decision real easy. LOL
Regardless, that's still a decent warrenty, I mean 1/2 the guys I know will never see 100K on anything that they aren't using for work. I'll have had my truck for 2 years this January, and I have about 36500 on it right now. Mind you I was driving 62 miles a day to go to work too...
Now I'm down to 46 miles a day, so the mileage is gonna go on it a good bit slower I think.
But... for the $ you probably stole it for it will get the job done. 2wd too yes? Not that you really need the 4wd in florida
