Drag Racing Tech
5pt? 6pt? wolfe
Old Dec 17, 2010 | 08:27 PM
ajw2500hd's Avatar
Question 5pt? 6pt? wolfe
ok, why do people go for the 6pt and not just stick with the 5pt?
bolt in vs weld in? which do you guys like better?
thanks aj
Old Dec 17, 2010 | 08:58 PM
ajw2500hd's Avatar
also why does wolfe not offer swing outs on there 10pt cage?
Old Dec 17, 2010 | 09:36 PM
mike13's Avatar
not NHRA legal
Old Dec 17, 2010 | 09:38 PM
mike13's Avatar
thanks aj
I've seen a few 5 point bats in Corvettes but not F bodies, I went with a 6 point bolt in but also welded the main hoop to the floor.
Old Dec 17, 2010 | 09:47 PM
ajw2500hd's Avatar
Originally Posted by mike13
not NHRA legal
well that sucks!!! i guess i will never have a 10 point then cause i would have to have swing outs. wolfe makes a 5 point i was just thinking about the weight not really needed
Old Dec 18, 2010 | 02:33 PM
ajw2500hd's Avatar
Bump!
Old Dec 18, 2010 | 02:46 PM
AChotrod's Avatar
Swing outs ARE legal to 8.50 and a correctly installed bolt in is stronger than a weld in roll bar.
Edited for correct ET
Old Dec 18, 2010 | 02:57 PM
RamAir95TA's Avatar
5 points just look dumb.
Old Dec 18, 2010 | 03:10 PM
AChotrod's Avatar
that also^^^
Old Dec 18, 2010 | 06:21 PM
ajw2500hd's Avatar
ok so if am already going 135mph+ i cant have swing outs?????
Old Dec 18, 2010 | 08:12 PM
RamAir95TA's Avatar
Man, if I'm going 135+ mph, do you really WANT swingouts?
Old Dec 18, 2010 | 08:53 PM
logic factory's Avatar
Originally Posted by AChotrod
... and a correctly installed bolt in is stronger than a weld in roll bar.
could you explain this?
Old Dec 19, 2010 | 11:44 AM
Nsty98LS1's Avatar
x2. i've never heard anything like that
Old Dec 19, 2010 | 12:31 PM
AChotrod's Avatar
Well from what ive read its because they use backing plates that sandwich the floor pans and distribute the pressure more evenly. Now Im only talking about a 4-5-6 pt roll bar not a full cage.
Old Dec 19, 2010 | 09:44 PM
SS4Luck's Avatar
Really? i cant see that being true. Im not calling you on it, but i just see it being like SFCs. Weld ins are light years stiffer and more functional than bolt ins
that also^^^
+2
Old Dec 20, 2010 | 01:02 AM
Doughboy692's Avatar
Page 20.25 of the 2010 NHRA rule book (the 2011 is not out yet but I expect it to be the same since a change is not listed in the 2011 rule updates)
Swing out side bar permitted on OEM full bodied car 8.50 et and slower.
Then they list the requirements.
Old Dec 20, 2010 | 01:11 AM
thanks aj
five points are cheaper and they take less time to install they are also lighter but the do not keep the car as stiff as a six point.
bolt in VS weld in. bolt in is easier to install but slightly heavier due to 6X6 plates on the bottom as well as the top. Bolt in is easier to remove if you ever want to sell it or quit racing and dont need it anymore
I have no preference it depends on what you are going to do with the car. If you just need to be legal and dont plan on ever making the car go 9.99 or 135 go either way. If you plan on one day getting to 9.99 or 135 but need a bar for now go bolt in. Then you can take it out and sell it when you move up to a cage and sell it.
Old Dec 20, 2010 | 06:25 AM
Fireball's Avatar
5-pts give you zero protection on the passenger side incase of rollover...symmetry is a good thing for protection!
swingouts are legal to 8.50...from the 2011 rulebook
Swing-out side bar permitted on OEM full-bodied car 8.50 e.t. and
slower
Old Dec 20, 2010 | 08:26 AM
Dan / Wolfe Race Craft's Avatar
Oh they are legal. We just wont do them on a full cage. We don't like the idea of making the door bar multiple pieces. That bar is there for a reason in-case something happens.
Old Dec 20, 2010 | 08:36 AM
ajw2500hd's Avatar
whats the weight difference between 6pt bolt-in vs. 6pt weld-in
